+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 2
    Points: 936, Level: 6
    Join Date
    Jul 2008
    Pune
    Posts
    23
    Points
    936
    Level
    can we determine dielectric constant of material practically
    I have manyfactured simple circular patch antenna for resonant frequency 2.45 GHz. But while testing it is showing that it is resonated at 2.48 GHz. Rest all parameters are as per specifications. I thnk problem will b in εr. i selected FR4 material and εr=4.4 for simulation.
    Plz help regarding this.....
    •   Alt22nd June 2010, 10:23
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,214, Level: 34
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,214
    Level
    34
    You see,
    FR4 isnt a standard thing!
    Its only a type of material & with an +/- εr value (eventually +/- 20%!) by all vendors....
    You have to ask everytimes by impedance critical (PCB) designs your source_or PCB producer_ for the especially used/ possible exact Er-values.
    Typicall has εr a range of 4.4...4.8 / .
    K.
    1 members found this post helpful.
    •   Alt22nd June 2010, 10:59
      advertising
  3. #3
    Join Date
    Jul 2008
    Pune
    Posts
    23
    Points
    936
    Level
    Re: can we determine dielectric constant of material practic
    Thanks....
    may i get information about practical calibration of dielectric material?
    •   Alt23rd June 2010, 06:53
      advertising
  4. #4
    volker_muehlhaus
    The common test method is IPC-TM-650 2.5.5.5
    http://www.ipc.org/4.0_Knowledge/4.1..._2-5-5-5-1.pdf
  5. #5
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,214
    Level
    34
    Try for appl notes i.e. by HP VNAs...
    K.
    Added after 5 minutes:
    Hi Volker,
    besten Dank!
    Its a good source ...
    K.
