+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 3
    Points: 762, Level: 6
    Join Date
    Jun 2009
    Bangalore
    Posts
    28
    Points
    762
    Level
    IPC Class and density
    Hi all,
    In the earlier version of IPC I have seen footprint land pattern calculated based on IPC class (1, 2 Or 3).In the latest one (IPC7531) it is based on density level. Do IPC have any calculation based on considering both (Class and density)
    Regards,
    N.Raghavan
    •   Alt21st June 2010, 13:12
      advertising
  2. #2
    Advanced Member level 3
    Points: 9,214, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    859
    Points
    9,214
    Level
    22
    IPC Class and density calculation
    Try asking on the PCBmatrix forum, after all they wrote the spec & software.
    Or perhabs PCBM will be along to answer you.
    Please do not PM me questions that are better asked in the PCB forum :)
    •   Alt21st June 2010, 18:35
      advertising
  3. #3
    Join Date
    Jun 2009
    Bangalore
    Posts
    28
    Points
    762
    Level
    Re: IPC Class and density calculation
    Thanks.Let me check.
    Regards,
    N.Raghavan
    •   Alt22nd June 2010, 05:13
      advertising
  4. #4
    Full Member level 5
    Points: 3,114, Level: 13
    loosemoose's Avatar
    Join Date
    Dec 2008
    Vancouver, BC
    Posts
    319
    Points
    3,114
    Level
    13
    you have 3 classifications to IPC footprints.
    Least, nominal and most. they refer to manufacturing levels.
  5. #5
    Join Date
    Jun 2009
    Bangalore
    Posts
    28
    Points
    762
    Level
    Hi loosemoose,
    Yes. You are right.
    But earlier it is based on the criticality of the products (class1, 2 OR 3).So my question here is
    1. Why earlier Land pattern based on criticality of the product and now why it is based on density of the product.
    2. Is there any IPC standard which considers the both?
    Regards,
    N.Raghavan
    •   Alt23rd June 2010, 06:04
      advertising
  6. #6
    cyberrat's Avatar
    Join Date
    Jun 2001
    Posts
    859
    Points
    9,214
    Level
    22
    ISTR that you still have the three classes also the three methods of manufacture.
    Have you got the IPC7351 standard?
    Ask on PCBmatrix and you get the answer from the people that wrote the spec.
    Then come back here & let us know what you found out.
