vkchau
Member level 4
Hi, anyone help me what constraints should I set to achieve below:
1. For example, my design on Altera FPGA runs at 100MHz, and have two outputs. I want two signals to active at the same time. I mean the time difference between them is less than 1ns. Could I achieve that?
2. If yes, what constraint should I set, between two signals, clocks...?
Thanks
Thanks
