+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Advanced Member level 1
    Points: 4,132, Level: 15
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    PT100 with PIC microcontroller
    Dear ALL,
    i need a cisuit PT100 temparture sensor using pic ADC. your help will be highly appricated
    Regards
    •   Alt29th May 2010, 15:42
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: PT100 with PIC microcontroller
    1 members found this post helpful.
  3. #3
    Join Date
    May 2006
    Posts
    414
    Points
    4,132
    Level
    15
    thx IanP
    any one here to share practically used circuit ?
    •   Alt31st May 2010, 09:58
      advertising
  4. #4
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Here is a nice example of a compensated, opamp-based circuit that interfaces the PT100 to a microcontroller ..
    http://pdfserv.maxim-ic.com/en/an/AN3450.pdf
    It's based on MAXIM opamp, but I can't find any reason why it wouldn't work with any other rail-to-rail device ..
    Here is another one: "A precision interface for a Resistance Temperature Detector (RTD)"
    http://www.national.com/nationaledge/dec04/article.html
    Again, you are not obligated to use the specifically indicated opamp .. any rail-to-rail will do ..
    IanP
    :D
    •   Alt31st May 2010, 12:00
      advertising
  5. #5
    Banned
    Points: 999, Level: 7
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    Can I use 741 Op amp with the circuit shown here http://www.edaboard.com/attachments/...face1_5420.gif
    What changes should I make to the circuit?????
  6. #6
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Quote Originally Posted by internetuser2k11 View Post
    This circuit [pt100-precision-interface...] is designed to work as an instrumentation amplifier, and some of opamps’ inputs work with voltages very close to 0V/GND. For that one needs a rail-to-rail opamp.
    The LM741 has a minimum supply voltage, which from the top of my head is somewhere around +/-6V, that makes 12V single voltage configuration.
    If you want to connect output of [pt100-precision-interface...] to a microcontroller it has to be supplied of a single 0-5V power source. In this instance the LM741 is completely useless.
    Google for a rail-to-rail in/out opamp that is meant to work with single supply rail ...
    IanP
    2 members found this post helpful.
  7. #7
    Banned
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    OK. I used the same OP AMP as mentioned in the circuit. It is working fine. I want to know the exact o/p it gives / degree centigrade rise in temperature. including the increase in RTD resistance with increase in Temperature.
    How much does the resistance of rtd pt100 increase / degree C.
    what is the formula to be used with the above circuit for calibration???????????
    ---------- Post added at 11:39 ---------- Previous post was at 11:17 ----------
    Also I want to know the value of C1 @ this link http://www.edaboard.com/attachments/...face1_5420.gif
    Is it 1F or 1uF?
    ---------- Post added at 13:11 ---------- Previous post was at 11:39 ----------
    Quote Originally Posted by IanP View Post
    IanP
    :D
    What is the o/p mV/Degree C of the above circuit?
    The o/p of the circuit http://www.edaboard.com/attachments/...face1_5420.gif is not linear. What is its o/p formula?
    ---------- Post added at 14:28 ---------- Previous post was at 13:11 ----------
    What is the equation for the circuit http://www.edaboard.com/attachments/...face1_5420.gif
    The o/p is not linear.
  8. #8
    Banned
    Join Date
    Apr 2012
    Posts
    201
    Points
    999
    Level
    7
    The circuit shown here http://www.edaboard.com/attachments/...face1_5420.gif is giving an o/p of 0.01V @ 850 Degree C.
    I am getting wrong value. Please help me with the circuit. Tell me how to get the rtd pt100 resistance and temperature from Vo.
  9. #9
    Junior Member level 1
    Points: 870, Level: 6
    Join Date
    Aug 2012
    Posts
    19
    Points
    870
    Level
    @internetuser2k11 - How did you get the actual temperature value from Vo? Did you build a look up table? Where to find a look table for PT100 RTD - from the manufacturer?
    •   Alt20th September 2012, 19:31
      advertising
  10. #10
    Full Member level 5
    Points: 3,533, Level: 13
    js's Avatar
    Join Date
    Oct 2005
    Posts
    265
    Points
    3,533
    Level
    13
    Blog Entries
    vishay have nice application notes and informations:
    http://www.vishay.com/resistors-non-linear/
    http://www.vishay.com/resistors-non-...putation-list/
    you get excel table .... insert your sensor data and you get values....
    ______________________________________________
    Stupid questions are better than stupid mistakes.
