Microstrip Antenna with coaxial feed
zfeiyu
Dear Friends,
I am studying the patch antennas . I am confused by the coaxial feed type, here is my questions and thank you very much for answering.
1, how can I locate the feed point? Is the distance from edge calculated as the same way as the inset feed?
2, can I treat the coaxial line as the input impedence? Is the lenght of the line determined by the antenna?
I appreciate your answers[/b]
rectangular patch antenna, coaxial feed.
Added after 5 minutes:
built it and simulated!
but I want to put a waveguide to cover it enable the radiowave travelled inside the waveguide and see the energy propagation.
Could you recommend some references?
Thanks
