[SOLVED] logic converter IC for 3.3v to TTL and TTL to 3.3v
sahin5002
Member level 2
Bangladesh
I need a IC like max232
max232 converts the logic level TTL to RS232 and RS232 to TTL.
I need a chip which can converts the logic level from 3.3v to TTL and TTL to 3.3 v non-inverting.
Now i am using transistor to do this. But I want to use an IC. Help me to finding the IC.
Choose a voltage-level translator with this tool at TI.
No you can't use MAX3232, the output voltage is higher and also swings to negative voltage too (about +5.5v to -5.5v)
Alex
---------- Post added at 23:56 ---------- Previous post was at 23:54 ----------
You can use a mosfet as a bidirectional level shifter
d.holmes > hardware > simple bus level-shift
