+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Member level 3
    Points: 1,839, Level: 9
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    AD8067 in Multisim - problem with supply!
    Hi all!
    I have pretty strange issue. I wanted to use AD8067 opamp in my design, but despite it's rated to to 5-24V supply voltages, when I supply it with anything above +-5.42V, then the output of amplifier in inverting topology is equal to almost -Vcc and there are ripples of similar shape to the input signal.
    How to overcome that to be able to simulate circuit with +-12V supply as it can go ?
    Best regards,
    Micard
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: AD8067 in Multisim - problem with supply!
    It doesn't make sense ..
    If you can, post your *****.msxx file ..
    IanP
  3. #3
    Member level 3
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    Sure, here you are. When you change the voltage of DC power sources do 5V everything is as expected. But when i put +-6V . I have ~-Vcc and small ripple of signal's frequency.
    Mike
    •   Alt20th May 2010, 09:45
      advertising
  4. #4
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Basic question: Dual or single supply? (Perhaps you have applied single supply without proper biasing?).
    My question is because I cannot read your file - even after unzipping. Is it really necessary to zip?
  5. #5
    Member level 3
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    It's dual.
    Unfortunately yes - edaboard checks extensions. My file is opamp.ms10 The file in this post is just one with extension changed to *.r00
  6. #6
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Another question: Which gain are you going to realize? (As I still cannot read your file). Do you know that the opamp is stable only for gain values larger than 8 (according to AD data sheet).?
    1 members found this post helpful.
  7. #7
    Member level 3
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    I haven;t seen it.. thank you very much for pointing me this thing.
    But still I use larger gain.
    Se pictures below - only supply is changed
    •   Alt20th May 2010, 10:26
      advertising
  8. #8
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    This is simulator, so you have to follow rules, and the rule says that a resistor should be connected to input(+) and its value should be equivalent to the impedance (or resistance) "seen" by input (-), what basically means R2 and R3 in parallel ..
    Add R1 and all should go back to normal ..
    IanP
    :D
  9. #9
    Member level 3
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    totally true !
    Thank you very much.. I have already spent some time at this silly mistake :/
  10. #10
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Quote Originally Posted by micard
    totally true !
    I can't understand. Was this really the cause of trouble?
    Here is the reason for my doubts:
    Quote IanP:
    There is absolutely no requirement (rule) that a resistor "should be connected to input(+)". Such a resistor is good for compensation of dc input currents in order to avoid a shift of the operating point. However, as far as I know, the opamp used has a FET input stage, does it not?. In this case, there is no need to compensate dc currents and I would be surprised that this was the cause of the problems mentioned. (Even for BJT input stages and a 1k gain resistor the dc input current should have liitle influence).
    Please inform me about results.
  11. #11
    Junior Member level 3
    Points: 1,050, Level: 7
    AdrianN's Avatar
    Join Date
    Jun 2009
    California
    Posts
    27
    Points
    1,050
    Level
    7
    totally true !
    This thread goes into the wrong direction and the conclusion is false.
    LvW is right. There is no such rule in a simulator to add a resistor in the non-inverting input. We might add a small resistor to help the simulator converge to a solution but this is not the case. The rule applies in real life for Op Amps with large input bias currents to help reduce the offset that otherwise would be generated by the voltage drop on the inverting input resistors. Not for AD8067 with its picoamp bias currents.
    The AD8067 model is broken, or Multisim does not interpret it correctly. If you insert a current probe in the non-inverting input you will find a huge current. The suggested solution with a resistor in the non-inverting input compensates for this problem, but the offset is still large.
    I suggest you create your own behavioral model for AD8067 from its data sheet.
  12. #12
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Thanks, AdrianN !
    So, the opamp model has errors as you have found out.
    Now my conception of the analog world is again restored.
  13. #13
    Member level 3
    Join Date
    Oct 2009
    Soenderborg
    Posts
    66
    Points
    1,839
    Level
    9
    Thanks AdrianN for clearing the case. I indeed had a covergence problems sometimes (without use of a resistor) at non inverting input.
    Do you know any tutorial explaining how to make own Spice models of opamps (or other devices)?
    Kind regards,
    Micard
    •   Alt21st May 2010, 12:22
      advertising
  14. #14
    AdrianN's Avatar
    Join Date
    Jun 2009
    California
    Posts
    27
    Points
    1,050
    Level
    7
    Multisim has a Component Wizard under Tools. You start the wizard, then click on simulation only, then choose the number of pins (5 in this case), choose a symbol (an op amp, copy from database). At model, start Model Maker. Choose Operational Amplifier and then fill up a table with the component specs.
    Multisim Help also has a section "Adding Components with the Create Component Wizard".
    You could also buy a book, The SPICE Book by Andrei Vladimirescu. Search for it at www.Amazon.com or get a link from the list of books in my website at www.MasteringElectronicsDesign.com.
    You can also create a "visual" model, by wiring one in Multisim. Start with a VCVS with a large gain (choose the AD8067 open loop gain), then add two input current sources for Ib, one voltage source for Vos in series with an input, one differential resistor between inputs, two common mode input resistors, a series output resistor for Ro. You can also add one pole with a VCCS and a combination of RC. You can also simulate the power supplies. Anyway, too long to explain here. The book should help you. I will soon have a short tutorial in my website. Keep an eye on it (RSS it).
  15. #15
    AdrianN's Avatar
    Join Date
    Jun 2009
    California
    Posts
    27
    Points
    1,050
    Level
    7
    I posted this tutorial. You can find it here:
    Build an Op Amp SPICE Model from Its Datasheet – Part 1
