isharan
Newbie level 6
S-parameters plots
dear all,
I had completed simulating a patch antenna in CST..
It has a ground slit. I modelled the patch and ground of the antenna using Extrude polygon method..the results for s- parameters seem ok.
But my problem is, i would like to plot the s11 for different ground slit length..namely 3 mm, 4 mm and 5 mm....
How to do this so that I cant get all the plots in the same graph...?
How to combine the results for various length changes in the same graph.?
Thank you for your consideration.
dear all,
