9 digit 7 segment LED Disply coding in c
adnanmehfooz
9 digit code in c
hi dear
i need 9 digit 89c52 or 89c51 code taht counts and display result on seven segment. i appreciate co-operation of any one in this regard.
9 digit code in c
dud,
you are not asking us to tell you something which is going to make you understand how you realize your idea,
you are asking us to do what you wanna do.
you should search it on the net, or pay someone to do this
Re: 9 digit code in c
dear
i have a code for 6 digit but there is a problem in it .below is the program please remove the errors.
when ever i run this programme it display 0.
#include <AT89X52.H>
unsigned char code dispbit[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code dispcode[] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00,0x40};
unsigned char dispbuf[8]={0,0,0,0,0,0,10,10};
unsigned char temp[8];
unsigned char dispcount;
unsigned char T0count;
unsigned char timecount;
bit flag;
unsigned long x;
void main(void)
unsigned char i;
TMOD=0x15;
TH0=0;
TL0=0;
TH1=(65536-4000)/256;
TL1=(65536-4000)%256;
TR1=1;
TR0=1;
ET0=1;
ET1=1;
EA=1;
while(1)
if(flag==1)
flag=0;
x=T0count*65536+TH0*256+TL0;
for (i=0; i<8; i++)
temp=0;
i=0;
while(x/10)
temp=x%10;
x=x/10;
i++;
temp=x;
for (i=0; i<6; i++)
dispbuf=temp;
timecount=0;
T0count=0;
TH0=0;
TL0=0;
TR0=1;
void t0(void) interrupt 1 using 0
T0count++;
void t1(void) interrupt 3 using 0
timecount++;
if(timecount==250)
TR0=0;
timecount=0;
flag=1;
P0=dispcode[dispbuf[dispcount]];
P2=dispbit[dispcount];
dispcount++;
if(dispcount==8)
dispcount=0;
9 digit code in c
This is probably RPM Code, so you need to give a pulse train on p3.4 to see some digits coming in.
