+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Newbie level 5
    Points: 506, Level: 4
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    Urgent!!!
    hi..can anybody tell me how to convert a sine wave form into a square waveform by using op-amps(IC-741 specifically)....its my term project and i have just half a week left to submit it so plzzz hurry and reply..plz be elaborative and include diagrams if possible..thanks.regards
  2. #2
    Full Member level 4
    Points: 2,251, Level: 11
    Join Date
    Mar 2010
    Posts
    207
    Points
    2,251
    Level
    11
    Re: Urgent!!!
    Dude, no one in this forum will do someone else's work. We only HELP. It is your work so you have to do it yourself.
    However I will help you.
    In order to convert a sine wave into a square wave you only have no use an Opamp (like IC-741) using a non-inverting amplifier circuit with a very large gain.
    The very large gain willl make the circuit saturate quickly, transforming your sine into a square.
    This site has exactly what you need:
    http://www.wisc-online.com/Objects/V...spx?ID=SSE7906
    You should use the "non-inverting amplifier", and not the "inverting" for 2 reasons:
    1) It does not invert the sinal (I supose that's what you want)
    2) It has very high input impedance (which is always good)
  3. #3
    Newbie level 5
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    Re: Urgent!!!
    hmmm..yeah that'l do it..thanks..ur a life saver!..:D
    •   Alt13th May 2010, 19:24
      advertising
  4. #4
    Super Moderator
    Points: 49,672, Level: 54
    Achievements:
    7 years registered
    keith1200rs's Avatar
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Urgent!!!
    Or just use the opamp like a comparator - no feedback.
    Keith
    I started life with nothing and I've still got most of it left. (Seasick Steve)
  5. #5
    Full Member level 4
    Join Date
    Mar 2010
    Posts
    207
    Points
    2,251
    Level
    11
    Re: How to convert sine wave into square wave using op-amp
    Yeah, that's right. Don't know how I didn't remebered that, how silly of me
  6. #6
    Newbie level 5
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    ohk thank you for your feedback . i was actually able to "test run" my circuit in the lab..but you see there's now a tiny miny BIG problem..i am now suppose to convert my square wave output into a trangular wave.:(..Now how i do that?..and also to convert a sine wave into square wave using IC-741 op-amp?...and my project is now worth 50% weightage of my total course..what a misery!!
    •   Alt16th May 2010, 22:03
      advertising
  7. #7
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    You need an integrator.
    Keith
  8. #8
    Full Member level 4
    Join Date
    Mar 2010
    Posts
    207
    Points
    2,251
    Level
    11
    Keith is right, you need an integrator. Check this out:
    http://www.wisc-online.com/objects/V...spx?ID=SSE5303
  9. #9
    Newbie level 5
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    that was an excellent help sir!!...i really appreciate it..and the slide show well that was so elaborative and easy to understand:)..thanks once again.you ppl are great help..kkep up the good work:D
  10. #10
    Newbie level 5
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    hey!! hey.!!:D..i made the project and m just a day away from showing it to my teacher..guys ive made the integrator and adjusted the but i didnt have any idea what i was doing actualy..i read it somewhere that if you change the resistance and capacitance you can adjust the wave into traingular wave but what i want to ask is that is there any specific easy to understand "formula" for voltage output of an integrator?..not that one that includes an 'integral' type of stuff but a simple universal formula so i can easily understand it and make my teacher understand it as well:)..thanks waiting for ur feedback
    •   Alt17th May 2010, 09:23
      advertising
  11. #11
    Super Moderator
    Achievements:
    7 years registered
    Join Date
    Oct 2009
    Yorkshire, UK
    Posts
    10,877
    Points
    49,672
    Level
    54
    Unfortunately an integrator integrates, so it is difficult to avoid integration in the explanation:
    http://en.wikipedia.org/wiki/Operati...ing_integrator
    In simple terms, the output will decrease (because it is inverting) at a rate determined by the resistor and capacitor at dV/dT=-Vin/RC so if you had 100k and 100nF and a 5V signal, for example, the output would change at the rate of 500V/s.
    Keith.
    Added after 3 minutes:
    The simple explanation, by the way, is that the opamp keeps the inverting input at zero volts, so the current in the resistor is Vin/R. This current must go through the capacitor and the equation for a capacitor charge (Q=CV), when differentiated gives I=C.dV/dt. So, dV/dt=I/C = Vin/RC. The minus sign appears because of the dire4ction of the current in the capacitor, resulting in -Vin/RC.
    Keith.
  12. #12
    Advanced Member level 5
    Points: 39,702, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,689
    Points
    39,702
    Level
    48
    Perhaps TANSAH wants to see an integral explicitely in the formula.
    Therefore, read this explanation for an intergator circuit (without signal inversion):
    * Voltage across a capacitor: Vc=(1/C)∫idt with i=Vin/R (due to virtual ground at the inverting opamp terminal)
    * Thus, Vc=(1/RC)∫(Vin)dt.
    * For Vin=const. this leads to Vc=(1/RC)*Vin*t (>>linear ramp prop. to time t).
    Perhaps this helps.
  13. #13
    Newbie level 5
    Join Date
    May 2010
    Posts
    10
    Points
    506
    Level
    yeah i think i have understood most of it..thanks once again ppl:)
