upengan78
Junior Member level 1
One user is reporting below issue.(Cent OS)
During the conversion from netlist to schematic user keep having a memory error.
User tried all the 3 suggestions they give in the log file, but the problem persists.
Any idea. Appreciate your help.
Thanks.
@(#)$CDS: conn2sch version 6.1.4 02/09/2010 21:16 (sjfdl233) $ Thu May 6 14:54:03 2010
WARNING (CONN2SCH-135): Signal 'gnd!' terminates with '!' but is not defined as global in the source cell
view. This signal would be marked global by the schematic extractor.
INFO (CONN2SCH-372): Checked-in schematic PM_CASCODE_FINAL_LAYOUT_HANDLEERROR (CONN2SCH-568): A memory error has occurred during cellview import. Use one or more of the
following settings to import the design again:
1. Turn off the Full Place and Route option in GUI or use the +place_only in
standalone mode.
2. Turn off the Extract Schematics option in GUI or use the +noxtrsch option
in standalone mode.
3. Turn off the Analog Schematic Generation option in GUI or avoid the use of
the -asg option in standalone mode.
Thanks.
