+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 5
    Points: 3,089, Level: 13
    Join Date
    Jan 2006
    Posts
    287
    Points
    3,089
    Level
    13
    TX and RX using one Optical fiber?
    Is there any fiber in which TX and RX is using one Optical Fiber? If yes please give its details a bit..
    •   Alt5th May 2010, 07:10
      advertising
  2. #2
    Advanced Member level 5
    Points: 74,061, Level: 66
    Join Date
    Oct 2004
    West Coast
    Posts
    7,942
    Points
    74,061
    Level
    66
    Re: TX and RX using one Optical fiber?
    You can transmit TX on one wave length and RX on different wave length and multiplex them to one optical fiber, or you can use so called PPLED (ping-pong LED) - see some details here:
    http://www.fiber-optics.info/article...ptic_detectors
    http://www.digchip.com/datasheets/pa...ACS401-pdf.php
    IanP
    •   Alt5th May 2010, 07:57
      advertising
  3. #3
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    Also TDM or FDM may be solution in some applications. Intended data rate and transmission distance should be mentioned at least.
    •   Alt5th May 2010, 10:30
      advertising
  4. #4
    Full Member level 1
    Points: 3,068, Level: 13
    srhoar's Avatar
    Join Date
    Jul 2002
    The center of the World - Dallas
    Posts
    119
    Points
    3,068
    Level
    13
