+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 2
    Points: 713, Level: 5
    karthi_keyan's Avatar
    Join Date
    Sep 2009
    coimbatote
    Posts
    21
    Points
    713
    Level
    interfacing ACS756(HALL Current sensor)+(ADC-PIC)
    hai ALL,
    presently am designing power monitoring system project.
    In that am using ACS756 IC(hall effect current sensor IC). it gives sinusoidal output corresponding to the load(normal -1.6 DC in multimeter)
    when i trying to interface it with ADC of my controller, i try to catch the peak voltage of ADC for corresponding loads.but the out put is not stable.i think i have to follow some steps to measure the current.
    could u suggest me some solution how measure the current from ACS 756?thanks for your support.
    regards,
    karthikeyan
    •   Alt4th May 2010, 12:14
      advertising
  2. #2
    Member level 4
    Points: 871, Level: 6
    Join Date
    Jun 2010
    USA
    Posts
    70
    Points
    871
    Level
    Re: interfacing ACS756(HALL Current sensor)+(ADC-PIC)
    Quote Originally Posted by karthi_keyan
    How did you get this idea...
    ACS756 gives an analog output proportional to the current is is measuring and not a sinusoidal signal. Please read through : http://www.allegromicro.com/en/Produ..._Numbers/0756/
    and
    http://www.allegromicro.com/en/Produ.../0756/0756.pdf
    •   Alt13th July 2010, 01:52
      advertising
  3. #3
    Points: 12,797, Level: 27
    Fragrance's Avatar
    Join Date
    Jul 2002
    East Of Earth
    Posts
    1,187
    Points
    12,797
    Level
    27
    Hi
    better visit link under given to under stand how it could be done,here is the formula
    Amps = ( Ain - 511.5 ) / 20.46
    http://www.picbasic.org/showthread.p...+effect+sensor
    regards
    Fragrance
