What is the principle of digital LCR meter functioning?
supi
Junior Member level 1
What is principle of working of digital LCR meter? I did not get its block diagram on net. I am using Autocompute LCR meter by Aplab.
Re: digital LCR meter
Are you trying to say you didnt get Block diagrams and schematics of the Aplab LCR meter? If yes, how can you expect a public company to expose its bussiness secrets?
hello supi ,
i am not aware of the internals of the autocomput lcr meter.but i can give you the basic method ,which was seen from a very old digital lcr meter. a sinewave of known voltage and frequency is generated.(digtally).passed through the 'component under test'. current and its phase shift is measured in 'cut'.
computation of reqd parameters(L /C, R ) and other values is done . (usually in a microprocessor or microcontroller). and displayed.
srizbf
    supi
