temp sensor problem in mikro c pro
newbie111
Member level 2
h.k
hi folks
i am using 16f690 8 m external osc compile everything with mikro c pro
i followed the examples and made this temp logger
everything worked out
i have been trying to write some codes to turn off the led on portc.7
when a certain degree is reached (let's say led goes off when it is 20 degrees)
but
i failed to do so
if anyone knows how to make it, pls kindly teach me
Thank you so much in advance
sbit LCD_RS at Rc4_bit;
sbit LCD_EN at Rc5_bit;
sbit LCD_D4 at Rc0_bit;
sbit LCD_D5 at Rc1_bit;
sbit LCD_D6 at Rc2_bit;
sbit LCD_D7 at Rc3_bit;
sbit LCD_RS_Direction at TRISc4_bit;
sbit LCD_EN_Direction at TRISc5_bit;
sbit LCD_D4_Direction at TRISc0_bit;
sbit LCD_D5_Direction at TRISc1_bit;
sbit LCD_D6_Direction at TRISc2_bit;
sbit LCD_D7_Direction at TRISc3_bit;
const unsigned short TEMP_RESOLUTION = 12;
char *text = "000.0000";
unsigned temp;
void Display_Temperature(unsigned int temp2write) {
  const unsigned short RES_SHIFT = TEMP_RESOLUTION - 8;
  char temp_whole;
  unsigned int temp_fraction;
if (temp2write & 0x8000) {
    text[0] = '-';
    temp2write = ~temp2write + 1;
  temp_whole = temp2write >> RES_SHIFT ;
  if (temp_whole/100)
     text[0] = (temp_whole/100)  + 48;
          else
                    text[0] = '0';
  text[1] = (temp_whole/10)%10 + 48;
  text[2] =  temp_whole%10     + 48;
  temp_fraction  = temp2write << (4-RES_SHIFT);
  temp_fraction &= 0x000F;
  temp_fraction *= 625;
  text[4] =  temp_fraction/1000    + 48;         // Extract thousands digit
  text[5] = (temp_fraction/100)%10 + 48;         // Extract hundreds digit
  text[6] = (temp_fraction/10)%10  + 48;         // Extract tens digit
  text[7] =  temp_fraction%10      + 48;         // Extract ones digit
  Lcd_Out(2, 5, text);
  UART1_Write(10);
  UART1_Write(13);
  UART1_Write_Text("Current temp: ");
  UART1_Write_Text (text);
  delay_ms(2000);
void main() {
    ANSEL  = 0;
  ANSELH = 0;
  C1ON_bit = 0;
  C2ON_bit = 0;
  trisc=0x00;
    portc.B7=1;
 Lcd_Init();
  Lcd_Cmd(_LCD_CLEAR);
  Lcd_Cmd(_LCD_CURSOR_OFF);
  Lcd_Out(1, 1, " Temperature: ");
  Lcd_Chr(2,13,223);
  Lcd_Chr(2,14,'C');
UART1_Init(9600);
Delay_ms(100);
  do {
    Ow_Reset(&PORTa, 2);                         // Onewire reset signal
    Ow_Write(&PORTa, 2, 0xCC);                   // Issue command SKIP_ROM
    Ow_Write(&PORTa, 2, 0x44);                   // Issue command CONVERT_T
    Delay_us(120);
    Ow_Write(&PORTa, 2, 0xBE);                   // Issue command READ_SCRATCHPAD
    temp =  Ow_Read(&PORTa, 2);
    temp = (Ow_Read(&PORTa, 2) << 8) + temp;
    //--- Format and display result on Lcd
    Display_Temperature(temp);
    Delay_ms(500);
 } while (1);
