Rambo55
Banned
I fine the best photo paper to Iron On your Circuit is Komax Plus 150g you do not have to put in water all you do is print with the laser printer clean the board Iron on do not press down to hard just heat get the blade lift one side slow if any of the circuit is still on the photo paper put more heat and press a little on the spot untill all the circuit is on the board some time you can remove all the phone paper all the way. i have made two side board and single side board.
I have found the best software for all the project is Diptrace you can make any Pattern and Component.
