i need to detect the peak to peak value of a sine wave
royvincent
Member level 2
India
peak detection
i need to detect the peak to peak value of a sine wave. i have some circuits, but the problem is the required bandwidth is 10Hz-200KHz and none has worked out properly. NEED HELP URGENTLY.....
PLEASE.
peak detection
have u tried the calibration?is it ok if you detect +ve peak and display 2 times which assumes -ve peak same as positive?
Re: peak detection
ya, its enough to find only the positive peak value and get it multiplied with 2.
my main problem is, the circuits i tried is having capacitors to hold the peak value. but at high frequencies its not getting enough time to charge completely:cry: so the voltage across the capacitor is not the actual peak value. how much ever time i give, its not getting charged completely at high frequencies. i think this capacitor need to be eliminated. any idea how to do it?
Re: peak detection
200 kHz isn't actually a very high frequency. Classical peak detector circuits can handle it with sufficient fast OPs. In any case,
you have to be aware of non-ideal circuit properties, so the design has to start with - besides operation frequency - a specification
of relative and absolute error and acceptable droop.
peak detection
For fast peak detects, I quite like the dual opamp circuit:
Keith.
Re: peak detection
I just tried with my circuit but used faster op amp. also switched the capacitor 2 or 3 times while going from low to high frequency. now things are working perfectly...:D
surely i will try your circuit also....
THANKS
peak detection
Peak detects are quite demanding of opamp performance, particularly slew rate.
Keith.
Re: peak detection
Ya, slew rate was a problem for me.
Re: peak detection
The second circuit, that was the thing i said i tried.... But earlier tried with a very ordinary op amp... now ok.
THANKS EVERYBODY.
peak detection
The problem with the simpler circuits is the output sits at the negative rail so when a pulse comes along it has a long way to get to the peak value. The dual opamp version I posted holds the output one diode volts drop below the input so the output hasn't got as far to go when a peak comes along, so the slew rate requirement is less.
Keith.
Re: peak detection
ok, will surely try it... and see the difference.
Hi, What OP AMPs did you end up using if I might ask?
John
