+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 4
    Points: 3,006, Level: 12
    Join Date
    Jun 2008
    Posts
    196
    Points
    3,006
    Level
    12
    Dxf to Grber
    Hello,
    is there a free software which convert Dxf to gerber and vice versa......
    thank you in advance,
    N
    •   Alt14th April 2010, 12:17
      advertising
  2. #2
    Member level 2
    Points: 835, Level: 6
    Join Date
    Mar 2010
    INDIA
    Posts
    47
    Points
    835
    Level
    is there a free software which convert Dxf to Gerber?
    HI,
    you can use PADs free version for it. you have to import DXF file. then have to save your project and the have to generate gerber.
    You can try this method to other software also but I am not sure except PADs.
    1 members found this post helpful.
    •   Alt14th April 2010, 13:33
      advertising
  3. #3
    Full Member level 4
    Join Date
    Jun 2008
    Posts
    196
    Points
    3,006
    Level
    12
    Re: is there a free software which convert Dxf to Gerber?
    Hi spidyelectronics,
    I did not find free pads software, pls, could you give the link?
    Also,
    when i tried to export one line with two vias in gerber format, the schematic is not the same as done in ADS layout, i.e, it added two pas related to vias.
    in attached the layout, when it exported to gerver and the warning message.
    i wanna let you know that i verified the fractional digits in gerber and in layout but the same message appears when i tried to export the line including two vias.
    Thank you in advance
    •   Alt14th April 2010, 14:13
      advertising
  4. #4
    Full Member level 4
    Join Date
    Jun 2008
    Posts
    196
    Points
    3,006
    Level
    12
    i download pads software Nov.2009 but it could not read my dxf since my ADS layout is newer than pads software so i do know which software is convenient !!!
  5. #5
    Full Member level 4
    Join Date
    Jun 2008
    Posts
    196
    Points
    3,006
    Level
    12
    here, the site including
    dxf to gerber conversion
    Added after 11 seconds:
    http://www.edaboard.com/ftopic342963.html
    •   Alt14th April 2010, 23:48
      advertising
  6. #6
    Points: 11,322, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,322
    Level
    25
    line can not be transferred to Gerber.
    Theoretically line will not have a width.
    This is the problem, because gerber is generated by specific line width called resolution of the plotter.
    so instead line, use trace whose width is same as resolution of the plotter.
