CST Microwave studio 2009 installation guide
isharan
Newbie level 6
I would like to install the CST MW studio 2009 in my PC. I managed to install it.
But somehow, I cant open it bcoz the "Specify server" pop -up.
My questios are:
Shall i select local / remote?
By default it comes to A\lience.dat...then it stuck
Could some pls guide me with the installation?
Thank you.
I am using the DVD for CST 2009 suite.
My PC is win XP, pentium 4, 1 GB RAM , 320 GB HD
Reactions: dobir
    dobir
Dear Friends,
I am new on CST and I tried to install CST Studio Suite 2009 on my Vista and Windows 7 computers. But, I had a problem to specify license on both machines. I do not know what to do with Local or Remote license server types. I put the link where my license.dat file is in CST folder with port number 27000 but it said me that 'unable to start local license server'. what can I do?
I tried to open the program as administrator but it did not work :(
regards,
Isa
Hi
You should open your license.dat and in te first line instead of "SERVER .... ANY..... " write name of your computer after SERVER and write 27000 after ANY.
it should work!
shahram
Hi
it should work!
shahram
right on license.dat and click open with..
choose notepad, and then write computer name after server..just like this picture...
    V
Replace server name in license.dat with your computer name. Copy license.dat into the CST installation folder.
Run License Managaer & Start the service
When you run CST choose remote and input the computer name.
Hope this is helpful...If you do not solve it let me know.
Also I had a problem when installing the license manager on Vista but on XP it works fine
I did the same but still it is not working, while the license manager saying it is working. But when I open CST it does not work,,, Help please! Using XP.
Hi, I am unable to install CST 2009 on My windows 7 - 32 bit PC. In the pop-up specify license i wrote name of my PC, but it says erroe code - 18. Can you please help me to sort out this problem?
I am trying to Install CST 2008 on Windows 7 64 bit Professional, the problem is coming after patching when i run license manager to start the service it show an error in starting the service and hence i am also unable to start the CST.
can you help me in this. and also should I put the computer name as NAME-PC or only NAME
Hi
it should work!
shahram
it worked, mirshahram. thank you so much.
