+ Post New Thread
Page 1 of 10 1 2 3 ... LastLast
Results 1 to 20 of 188
  1. #1
    Full Member level 4
    Points: 5,939, Level: 18
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    icd0082
    Hi everybody,
    I'm happy to say : I've make it and it works fine !!!
    It's only the version with RS232 interface, the USB comes later... perhaps.
    Enjoy and thanks to MCU!!!
    CD :D
    •   Alt20th April 2004, 18:29
      advertising
  2. #2
    Points: 9,431, Level: 23
    FoxyRick's Avatar
    Join Date
    Jan 2004
    England, UK
    Posts
    1,245
    Points
    9,431
    Level
    23
    icd0152
    Looks good...
    Do we know exactly which part the MCP41xxx is? 10K, 50K, 100K?
    Thanks for this,
    FoxyRick.
  3. #3
    Full Member level 4
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    icd2 rs232
    Ooops sorry for the missing part number reference. This is a 10k potentiometer.
    Have fun !!!
    CD :D
  4. #4
    Member level 2
    Points: 2,192, Level: 10
    Join Date
    Jun 2003
    Posts
    44
    Points
    2,192
    Level
    10
    serial icd2
    Hi Crazyduck,
    could you upload the project files in original ( not pdf) format - a shematic and a pcb.
    Thanks in advance.
    Best regards
  5. #5
    Junior Member level 2
    Points: 1,922, Level: 10
    snaper's Avatar
    Join Date
    Feb 2004
    Posts
    21
    Points
    1,922
    Level
    10
    ccs rs232
    hi crazy duck
    nice job could you upload it in protel format as other stuff i seen you do is done in prottel
    cheers
    spnare
  6. #6
    Full Member level 4
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    icd2 homemade
    Thge file in DXP format.
    CD:D
  7. #7
    Full Member level 5
    Points: 3,965, Level: 14
    Join Date
    Jul 2002
    Posts
    289
    Points
    3,965
    Level
    14
    mplab icd2 keeps looking for com2
    Quote Originally Posted by FoxyRick
    Looks good...
    Thanks for this,
    FoxyRick.
    hi all
    anyone knows an easiest-part-to-find instead of this Mchip 10K digital pot ?
    •   Alt21st April 2004, 08:47
      advertising
  8. #8
    Full Member level 4
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    74ahc126
    Digital potentiometer can be requested freely on the microchip website.
    CD:D
  9. #9
    Points: 2,436, Level: 11
    Join Date
    Mar 2003
    China
    Posts
    7
    Points
    2,436
    Level
    11
    pic12f629 icd0069: debug: unable to run target
    Hi Crazyduck,
    Could you upload the project pcb files ( not pdf) ?
    Thanks in advance.
  10. #10
    Full Member level 4
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    si4435 replaced
    It's done look on the board you'll find files in protel format.
    CD:!
    •   Alt21st April 2004, 10:18
      advertising
  11. #11
    Full Member level 3
    Points: 4,018, Level: 14
    Join Date
    Aug 2001
    EU
    Posts
    183
    Points
    4,018
    Level
    14
    home made icd2
    You can use common trimmer instead of digital pot.
    It is switched on the same value, still.
    pool_77
  12. #12
    snaper's Avatar
    Join Date
    Feb 2004
    Posts
    21
    Points
    1,922
    Level
    10
    16f877 icd2
    CD
    there is only the schematic file in the rar folder
    could you upload the pcb lay out for us all
    cheers
    snaper
  13. #13
    Full Member level 4
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    16f876a max232
    This the pcb file in p*r*o*t*e*l d*x*p 2004 format.
    CD:)
    1 members found this post helpful.
  14. #14
    snaper's Avatar
    Join Date
    Feb 2004
    Posts
    21
    Points
    1,922
    Level
    10
    register difference between 877 and 877a wrt pic
    ver good job CD u must have worked very hard
    cheers
    snpaer )))
  15. #15
    Newbie level 6
    Points: 2,382, Level: 11
    Join Date
    Aug 2002
    Posts
    11
    Points
    2,382
    Level
    11
    invalid target mode for requested operation pic24
    Hi. CrazyDuck.
    I am Going to Make ICD2 to serial type.
    I have two schematic.
    Original shematic use PIC16F877A, the other use PIC16F877A
    But I don't know that Bootloader(MPLAP Original HEX) is operated different device(PIC16F877, PIC16F877A)
    I would like to use PIC16F877A in ICD2.
    Could you explain the question. Help me.
  16. #16
    Member level 3
    Points: 2,045, Level: 10
    Join Date
    Jul 2002
    Posts
    58
    Points
    2,045
    Level
    10
    update icd2
    Hi All,
    Does this firmware also include USB connection? Thank you.
    Regards
  17. #17
    Member level 3
    Join Date
    Jul 2002
    Posts
    58
    Points
    2,045
    Level
    10
    pic16f877 what does icd=true mean
    Hi All,
    Sorry, I miss out another question. Does this firmware support the firmware updates given from MPLAB? Please advice. Thank you.
    Regards
  18. #18
    Newbie level 5
    Points: 1,859, Level: 10
    Join Date
    Apr 2004
    Posts
    8
    Points
    1,859
    Level
    10
    disable release from reset with icd2
    Quote Originally Posted by asara1
    Hi. CrazyDuck.
    To use a 16F877A, the bootloader needs to be modified otherwise the Flash programming will fail when downloading new firmware. The attached file is modified to disable Flash write verify and should work fine with firmware updates.
  19. #19
    Full Member level 5
    Join Date
    Jul 2002
    Posts
    289
    Points
    3,965
    Level
    14
    max232+icsp+16f876a
    Quote Originally Posted by crazyduck
    It's done look on the board you'll find files in P*otel format.
    CD:!
    anyone can extract BOM from the p*r*o*t*e*l file ?
    thanks
    •   Alt22nd April 2004, 09:55
      advertising
  20. #20
    Full Member level 5
    Join Date
    Jul 2002
    Posts
    289
    Points
    3,965
    Level
    14
    icdwarn0038
    Quote Originally Posted by Zaphod42
    To use a 16F877A, ....
    euhhh always 16F877A
    i try to understand ???
    the original hex file provided by CrayzyDuck is for a 16F877 (NOT a 16F877A) even if its written 16F877A in the PDF file, is it the real situation ?
