[SOLVED] transconductance (u*Cox) parameter dependency to technology
A
ahmadagha23
hi
Do you know the relationship between transconductance (u*Cox) parameter and technology?
In other words how does change that parameter for a mosfet in .25 micron to 0.18micron?
Regards
Re: transconductance (u*Cox) parameter dependency to technol
Hi
Please read this topic , people in this forum discuss a lot about uCox. Thanks
ahmadagha23 said:
... relationship between transconductance (u*Cox) parameter and technology?
Below pls. find a table with those parameters for 3 different processes from D. Binkley's book "Tradeoffs and Optimization in Analog CMOS Design".
For 0.25µm tech., you can interpolate.
Hi Erik,
The document you attached does not include the division factor of 2 in the computation of Kn or Kp. Why would that be or is it always that case. If so, the other edaboard link mentioned in this post clearly shows that we have to include the factor 2 in the computation of Kn or Kp.
Also one more trivial question. Why is it called as Transconductance parameter. If my interpretation of this name meaning is right, then the computation of Kp or Kn doesnt involve the factor 2 (gm = (2*Id)/Vov).But still I miss thhe squared (Vov)^2 in the interpretation of this formula though
Thanks for helping
Falcon
Unfortunately the use of this division factor of 2 is handled differently in various books, depending on if it's already included in the transconductance factor (e.g. k'=k/2 or C'ox=COX/2) or not.
Why is it called as Transconductance parameter. If my interpretation of this name meaning is right, then the computation of Kp or Kn doesnt involve the factor 2 (gm = (2*Id)/Vov). But still I miss the squared (Vov)^2 in the interpretation of this formula though
Do not mix up the Transconductance parameter k'=µ0*C'ox [A/V2] with the transconductance gm = (2*Id)/Vov given in units of [A/V] !
thanks for the posting erik and also informing about the Kp parameter
Regarding the transconductance parameter, then I am really curious to know how it got named in that way if it has nothing to do with the transconductance(gm).
thanks
Falcon
Given Id=K/2*W/L*Vov^2
gm=K*W/L*Vov
K is essentially the transconductance per W/L per volt of overdrive.
It's just a normalisation procedure.
And that explains why it should not include the "divide by 2".
Added : This assumes that the MOS follows the simplistic square law.
For high density processes, deviations from the square law are bound to occur.
thanks checkmate
that was a brilliant explanation in my opinion.
besides being happy for it, I am still curious to know as how erik got the right answers as in datasheet for both Kp and Kn values.
falcon
... how it got named in that way if it has nothing to do with the transconductance(gm).
There's a convenient relation between the transconductance parameter k' and the transconductance gm :
gm = k'/n * W/L * Vov , s. e.g. David M. Binkley "Tradeoffs and Optimization in Analog CMOS Design" equ. (2.12), where n is the substrate factor.
Thanks Erik for mentioning about the transconductance parameter.
But could you please tell me as how you managed to get the right answer by having the factor '2' in your computation of Kp and Kn in the mentioned post happened before
falcon
... could you please tell me as how you managed to get the right answer by having the factor '2' in your computation of Kp and Kn in the mentioned post happened before
I think it's comprehensibly explained in the "mentioned post happened before". Don't forget:
Thanks Erik. I will refer to the mentioned book for more details.
