Whats the difference between DDFS and NCO?
Usman Hai
Full Member level 3
Canada
DDFS
Whats the difference bw DDFS and NCO.
USMAN HAI
PAKISTAN
Re: DDFS
NCO : Is a dgital technique of generating required frequency it basically uses a counter and provides rectangular waveform output.
DDFS : is a DSP technique. It may use the NCO, other digital techniques to create modify, .... and finally uses a DAC to conver it to analog form.
Hope this is useful.
BRMadhukar
Re: DDFS
DDFS: Direct Digital Frequency Synthesis
it use a high frequency (fs) clock source to generated low frequency anyshape waveform. The frequency of generated waveform should not exceed 1/20 to get a low harmonic output after DAC.
