Why is shielding done only with power and ground?
siddharth1501
Member level 1
india
hi all
why sheilding is done only with power and ground?
regards
siddu
Re: sheilding
hey,
Do you mean why sheilding is tie or connected to POWER or GND?
sheilding
because that is DC. If sheild voltage changes a lot, it will affect the signal.
Re: sheilding
Right VDD and GND are DC signals, but even though u can see noise bounces in both power lines. Can u plz tell me how it will be effected with this ?
Re: sheilding
Yes there are POWER/GND bounces, but still they are far better than other switching signal couplings.
power or gnd bounce will result in a glitch in the shielded line...usually gnd is preffered
hi all
regards
siddu
usually shielding requires a low impedance, low noise net, this usually correspond to a supply net. In general you can use any low impedance net even a dedicated one for shielding
