Interfacing JHD12864e GLCD with microcontroller
sory, its resolved some sort of program problem
hi,
I tested the code, the image are not drawn fully. i will attach the code
is there any mistake please let me to know. After successful completion i will post the working code
//// Extended_GLCD.c ////
//// by ////
//// SAINT (Caner ERSiL) ////
//// !!! PLEASE READ THIS INFO FIRST !!! ////
//// This file contains drivers for using a KS0108 based 128x64 pixel////
//// GLCD. This "Extended_GLCD.c" driver based on, "GLCD.c" driver ////
//// can be found in CCS installation folder. The driver treats the ////
//// upper left pixel as (0,0). ////
// ! DON'T FORGET TO CHANGE YOUR PIN CONFIGURATION FOR YOUR CIRCUIT ! //
//// The NEW functions added by me: ////
//// glcd_standby(command) ////
//// glcd_3Dbox(x,y,width,height,depth,color) ////
//// glcd_circle_seg(x,y,radius,angle_start,angle_end,color) ////
//// glcd_image(inverse) ////
//// glcd_image_xy(x,y,inverse) ////
//// !! YOU CAN FIND DETAILED DESCRIPTIONS !! ////
//// !! AND "HOW TO USE" INFORMATIONS ABOVE THE FUNCTIONS !! ////
//// Original(untouched) GLCD functions are: ////
//// glcd_init(mode) ////
//// glcd_pixel(x,y,color) ////
//// glcd_line(x1,y1,x2,y2,color) ////
//// glcd_rect(x1,y1,x2,y2,fill,color) ////
//// glcd_bar(x1,y1,x2,y2,width,color) ////
//// glcd_circle(x,y,radius,fill,color) ////
//// glcd_text57(x,y,textptr,size,color) ////
//// glcd_fillScreen(color) ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. Smile ////
#include <math.h>
#include <Bitmap.h>
#define GLCD_CS1 PIN_B0 // Chip Selection 1
#define GLCD_CS2 PIN_B1 // Chip Selection 2
#define GLCD_DI PIN_B2 // Data or Instruction input
#define GLCD_RW PIN_B4 // Read/Write
#define GLCD_E PIN_B5 // Enable
#define GLCD_RST PIN_C0 // Reset
#define DATAIN INPUT_D // Data input port (Should be same port as DATAOUT)
#define DATAOUT OUTPUT_D // Data output port (Should be same port as DATAIN)
#define GLCD_WIDTH 128 // Used for text wrapping by glcd_text57 function
#define ON 1
#define OFF 0
#define YES 1
#define NO 0
BYTE glcd_readByte(BYTE chip);
void glcd_writeByte(BYTE chip, BYTE data);
void glcd_fillScreen(int1 color);
const BYTE TEXT[51][5] ={0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x04, 0x02, 0x7F, 0x00, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76};// R
const BYTE TEXT2[44][5]={0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose: Initialize a graphic LCD. This must be called before any //
// other glcd function is used. //
// Inputs: The initialization mode //
// OFF - Turns the LCD off //
// ON - Turns the LCD on //
void glcd_init(int1 mode)
// Initialze some pins
output_high(GLCD_RST);
output_low(GLCD_E);
output_low(GLCD_CS1);
output_low(GLCD_CS2);
output_low(GLCD_DI); // Set for instruction
glcd_writeByte(GLCD_CS1, 0xC0); // Specify first RAM line at the top
glcd_writeByte(GLCD_CS2, 0xC0); // of the screen
glcd_writeByte(GLCD_CS1, 0x40); // Set the column address to 0
glcd_writeByte(GLCD_CS2, 0x40);
glcd_writeByte(GLCD_CS1, 0xB8); // Set the page address to 0
glcd_writeByte(GLCD_CS2, 0xB8);
if(mode == ON)
glcd_writeByte(GLCD_CS1, 0x3F); // Turn the display on
glcd_writeByte(GLCD_CS2, 0x3F);
else
glcd_writeByte(GLCD_CS1, 0x3E); // Turn the display off
glcd_writeByte(GLCD_CS2, 0x3E);
glcd_fillScreen(OFF); // Clear the display
// Purpose: Turns ON-OFF graphic LCD. Good solution on system standby //
// GLCD does not clear its memory map on OFF command. So last //
// screen shows up when ON command send to GLCD //
// Inputs: OFF - Turns the LCD off //
void glcd_standby(int1 command)
output_low(GLCD_E);
if (command)
glcd_writeByte(GLCD_CS1,0x3F);
glcd_writeByte(GLCD_CS2,0x3F);
else
glcd_writeByte(GLCD_CS1,0x3E);
glcd_writeByte(GLCD_CS2,0x3E);
// Purpose: Turn a pixel on a graphic LCD on or off //
// Inputs: x - the x coordinate of the pixel //
// y - the y coordinate of the pixel //
// color - ON or OFF //
// Output: 1 if coordinate out of range, 0 if in range //
void glcd_pixel(int x, int y, int1 color)
BYTE data;
BYTE chip = GLCD_CS1; // Stores which chip to use on the LCD
if(x > 63) // Check for first or second display area
x -= 64;
chip = GLCD_CS2;
bit_clear(x,7); // Clear the MSB. Part of an instruction code
bit_set(x,6); // Set bit 6. Also part of an instruction code
glcd_writeByte(chip, x); // Set the horizontal address
glcd_writeByte(chip, (y/8 & 0b10111111) | 0b10111000); // Set the vertical page address
output_high(GLCD_DI); // Set for data
data = glcd_readByte(chip);
if(color == ON)
bit_set(data, y%8); // Turn the pixel on
else // or
bit_clear(data, y%8); // turn the pixel off
glcd_writeByte(chip, data); // Write the pixel data
// Purpose: Draw a line on a graphic LCD using Bresenham's //
// line drawing algorithm //
// Inputs: (x1, y1) - the start coordinate //
// (x2, y2) - the end coordinate //
// Dependencies: glcd_pixel() //
void glcd_line(int x1, int y1, int x2, int y2, int1 color)
signed int x, y, addx, addy, dx, dy;
signed long P;
int i;
dx = abs((signed int)(x2 - x1));
dy = abs((signed int)(y2 - y1));
x = x1;
y = y1;
if(x1 > x2)
addx = -1;
else
addx = 1;
if(y1 > y2)
addy = -1;
else
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(i=0; i<=dx; ++i)
glcd_pixel(x, y, color);
if(P < 0)
P += 2*dy;
x += addx;
else
P += 2*dy - 2*dx;
x += addx;
y += addy;
else
P = 2*dx - dy;
for(i=0; i<=dy; ++i)
if(P < 0)
P += 2*dx;
y += addy;
else
P += 2*dx - 2*dy;
x += addx;
y += addy;
// Purpose: Draw a rectangle on a graphic LCD //
// fill - YES or NO //
// Dependencies: glcd_pixel(), glcd_line() //
void glcd_rect(int x1, int y1, int x2, int y2, int fill, int1 color)
if(fill)
int y, ymax; // Find the y min and max
if(y1 < y2)
y = y1;
ymax = y2;
else
y = y2;
ymax = y1;
for(; y<=ymax; ++y) // Draw lines to fill the rectangle
glcd_line(x1, y, x2, y, color);
else
glcd_line(x1, y1, x2, y1, color); // Draw the 4 sides
glcd_line(x1, y2, x2, y2, color);
glcd_line(x1, y1, x1, y2, color);
glcd_line(x2, y1, x2, y2, color);
// Purpose: Draw a 3D box on a graphic LCD (Ex: to make a 3D Button) //
// Inputs: (x, y) - the start point //
// (width, height) - size of the box //
// depth - 3D depth effect ratio of the box (2 or 3 is fine) //
void glcd_3Dbox(int16 x,int16 y,int16 width, int16 height, int depth, int1 color)
int16 i,j;
for(i=x;i<=x+width;i++)
glcd_pixel(i,y,1);
glcd_pixel(i,y+height,1);
for(i=y;i<=y+height;i++)
glcd_pixel(x,i,1);
glcd_pixel(x+width,i,1);
for(j=1;j<=depth;j++)
for(i=y+j;i<=y+height+j;i++)
glcd_pixel(x-j,i,1);
for(i=x-j;i<=(x-j+width);i++)
glcd_pixel(i,y+height+j,color);
// Purpose: Draw a bar (wide line) on a graphic LCD //
// width - The number of pixels wide //
void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
signed int x, y, addx, addy, j;
signed long P, dx, dy, c1, c2;
int i;
x = x1;
y = y1;
c1 = -dx*x1 - dy*y1;
c2 = -dx*x2 - dy*y2;
if(x1 > x2)
addx = -1;
c1 = -dx*x2 - dy*y2;
c2 = -dx*x1 - dy*y1;
else
addx = 1;
if(y1 > y2)
addy = -1;
else
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(j=-(width/2); j<width/2+width%2; ++j)
if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
glcd_pixel(x, y+j, color);
if(P < 0)
P += 2*dy;
x += addx;
else
P += 2*dy - 2*dx;
x += addx;
y += addy;
else
P = 2*dx - dy;
if(P < 0)
P += 2*dx;
y += addy;
else
P += 2*dx - 2*dy;
x += addx;
y += addy;
glcd_pixel(x+j, y, color);
// Purpose: Draw a circle on a graphic LCD //
// Inputs: (x,y) - the center of the circle //
// radius - the radius of the circle //
void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
signed int a, b, P;
a = 0;
b = radius;
P = 1 - radius;
do
if(fill)
glcd_line(x-a, y+b, x+a, y+b, color);
glcd_line(x-a, y-b, x+a, y-b, color);
glcd_line(x-b, y+a, x+b, y+a, color);
glcd_line(x-b, y-a, x+b, y-a, color);
else
glcd_pixel(a+x, b+y, color);
glcd_pixel(b+x, a+y, color);
glcd_pixel(x-a, b+y, color);
glcd_pixel(x-b, a+y, color);
glcd_pixel(b+x, y-a, color);
glcd_pixel(a+x, y-b, color);
glcd_pixel(x-a, y-b, color);
glcd_pixel(x-b, y-a, color);
if(P < 0)
P+= 3 + 2*a++;
else
P+= 5 + 2*(a++ - b--);
} while(a <= b);
// Purpose: Draw a segment of a circle on a graphic LCD //
// Inputs: (x,y) - The center of the circle //
// radius - The radius of the circle //
// angle_start - Start point angle of segment of circle //
// angle_end - End point angle of segment of circle //
// Example: (angle_start = 0 & angle_end = 360 draws a normal circle) //
// (angle_start = 0 & angle_end = 180 draws half circle (arc) )//
// Dependencies: glcd_pixel(), <math.h> //
void glcd_circle_seg(int x, int y, int radius, int16 angle_start, int16 angle_end, int1 color)
int x_round, y_round;
float angle;
#define DEGREE 2*3.14159265/360
for (angle = (float)angle_start; angle <= angle_end; angle += .9)
x_round = (sin (angle * DEGREE) * radius);
y_round = (cos (angle * DEGREE) * radius);
glcd_pixel(x + x_round, y + y_round, color);
// Purpose: Write text on a graphic LCD //
// Inputs: (x,y) - The upper left coordinate of the first letter //
// textptr - A pointer to an array of text to display //
// size - The size of the text: 1 = 5x7, 2 = 10x14, ... //
void glcd_text57(int x, int y, char* textptr, int size, int1 color)
int i, j, k, l, m; // Loop counters
BYTE pixelData[5]; // Stores character data
for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
if(textptr[i] < 'S') // Checks if the letter is in the first text array
memcpy(pixelData, TEXT[textptr[i]-' '], 5);
else if(textptr[i] <= '~') // Check if the letter is in the second array
memcpy(pixelData, TEXT2[textptr[i]-'S'], 5);
else
memcpy(pixelData, TEXT[0], 5); // Default to space
if(x+5*size >= GLCD_WIDTH) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
for(j=0; j<5; ++j, x+=size) // Loop through character byte data
for(k=0; k<7*size; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l<size; ++l) // The next two loops change the
{ // character's size
for(m=0; m<size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
// Purpose: Fill the LCD screen with the passed in color //
// Inputs: ON - turn all the pixels on //
// OFF - turn all the pixels off //
// Dependencies: glcd_writeByte() //
int i, j;
// Loop through the vertical pages
for(i = 0; i < 8; ++i)
glcd_writeByte(GLCD_CS1, 0b01000000); // Set horizontal address to 0
glcd_writeByte(GLCD_CS2, 0b01000000);
glcd_writeByte(GLCD_CS1, i | 0b10111000); // Set page address
glcd_writeByte(GLCD_CS2, i | 0b10111000);
// Loop through the horizontal sections
for(j = 0; j < 64; ++j)
glcd_writeByte(GLCD_CS1, 0xFF*color); // Turn pixels on or off
glcd_writeByte(GLCD_CS2, 0xFF*color); // Turn pixels on or off
// Purpose: Fill the graphic LCD screen with 128x64 bit converted image //
// Inputs: YES - Inverse of image (Raw data saved in ROM) //
// NO - Normal image (Raw data saved in ROM) //
// Dependencies: glcd_pixel(), glcd_init() //
// !! Check the "Bitmap.h" file !! //
void glcd_image(int1 inverse)
unsigned int i, j, k;
unsigned int16 count=0;
int width = 128;
int height = 64;
glcd_fillScreen(OFF); //Clears the screen (opt.)
if(inverse)
for(i=0;i<height;i+=8)
for(j=0;j<width;j++)
for(k=0;k<8;k++)
if(~bit_test(image[count],k))
glcd_pixel(j,i+k,ON);
count++;
else
for(k=0;k<8;k++)
if(bit_test(image[count],k))
count++;
// Purpose: Draw less or equal 128x64 pixels of image to the graphic LCD//
// screen on specified x, y coordinate //
// Inputs: (x, y) - The start coordinate //
// YES - Inverse of image (Raw data saved in ROM) //
// !!! PRLEASE BE CAREFULL !! //
// First 2 bytes of your image data must be size of your BMP //
// Example: If your BMP image size is 64x32, first 2 bytes should //
// be 0x40, 0x20 --> (64 = 0x40, 32 = 0x20) //
void glcd_image_xy(int x, int y, int1 inverse)
unsigned int16 count=2;
int width = image_xy[0];
int height = image_xy[1];
if(inverse)
for(k=0;k<8;k++)
if(~bit_test(image_xy[count],k))
glcd_pixel(x+j,y+i+k,ON);
count++;
else
for(k=0;k<8;k++)
if(bit_test(image_xy[count],k))
count++;
// Purpose: Write a byte of data to the specified chip //
// Inputs: chipSelect - which chip to write the data to //
// data - the byte of data to write //
void glcd_writeByte(char chip, BYTE data)
if(chip == GLCD_CS1) // Choose which chip to write to
output_high(GLCD_CS1);
else
output_high(GLCD_CS2);
output_low(GLCD_RW); // Set for writing
DATAOUT(data); // Put the data on the port
output_high(GLCD_E); // Pulse the enable pin
delay_us(2);
output_low(GLCD_E);
output_low(GLCD_CS1); // Reset the chip select lines
// Purpose: Reads a byte of data from the specified chip //
// Ouputs: A byte of data read from the chip //
BYTE data; // Stores the data read from the LCD
if(chip == GLCD_CS1) // Choose which chip to read from
else
DATAIN(); // Set port d to input
output_high(GLCD_RW); // Set for reading
delay_us(2);
output_low(GLCD_E);
delay_us(2);
delay_us(2);
data = DATAIN(); // Get the data from the display's output register
output_low(GLCD_E);
return data; // Return the read data
/* Data generated with bitmap2LCD */
/* 13/03/2009 21:37:33 */
/* Bitmap Source file : Caner Ersil.bmp */
const int image[]=
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,
0XC0,0XC0,0XC0,0XE0,0XE0,0XE0,0XE0,0XE0,0XF0,0XF0,0XF0,0XF0,0XF0,0XF0,0XF0,0XF0,
0XE0,0XE0,0XE0,0XE0,0XE0,0XC0,0XC0,0X80,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XFE,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X0F,0X07,0X03,0X03,0X01,0X01,0X01,0X01,0X01,0X01,0X01,0X01,
0X01,0X01,0X01,0X01,0X03,0X03,0X07,0X0F,0XFF,0XFF,0XFE,0XF8,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X7E,0X7E,0XD6,0XC6,0XC6,0XD6,0XFE,0XFE,0XFE,0XDE,0XD6,0XD6,
0XD6,0X56,0X7E,0X7E,0X7E,0X3E,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0X80,
0X80,0X80,0XC0,0XC0,0XC0,0XC0,0XE0,0XE0,0XE0,0XE0,0XE0,0XE0,0XE0,0XF0,0X70,0X70,
0X70,0X70,0X70,0X70,0X70,0X70,0X70,0X70,0X70,0X78,0X78,0X79,0X7F,0X7F,0X7F,0X7F,
0X7F,0X7F,0X7F,0X7F,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0XF8,0XF8,0XF8,0XF8,
0XF8,0XF8,0XF8,0XF0,0XF0,0XF0,0XF0,0XB0,0XF0,0XF0,0XF0,0XF0,0XF0,0X70,0X70,0XE0,
0XE0,0XE0,0XE0,0XE0,0XC0,0XC0,0X80,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X0F,0X0F,0X1F,0X1F,
0X1F,0X13,0X53,0X51,0XD1,0XC1,0X81,0X80,0XA0,0XC0,0XC0,0XC0,0XC0,0X40,0X40,0X40,
0X40,0X40,0X40,0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0X80,0X82,0X86,0X86,0X86,
0X84,0X84,0X84,0X8C,0X8C,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,
0XCC,0XCC,0X4C,0X4E,0X4E,0X4E,0X46,0X66,0X67,0X67,0X63,0X63,0X60,0X20,0X20,0X20,
0X30,0X30,0XB0,0XB0,0X90,0X90,0X98,0X98,0XD8,0XD8,0XDC,0XDC,0XDC,0XFD,0XFC,0XFC,
0XFC,0X7C,0X7C,0X79,0X79,0X7B,0XF3,0XF3,0XE7,0XCF,0X8E,0X9C,0X38,0X70,0X60,0X60,
0XC0,0XC0,0X80,0X80,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X01,0X01,0X03,0X03,0X07,0X07,0X0F,0X1F,
0X1F,0X3F,0X3F,0X7F,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFE,0XFE,0XFE,0XFE,0XFE,
0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,
0XFE,0XFE,0XFE,0XFE,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X7F,0X3F,0X3F,0X1F,0X0F,0X0F,0X07,0X03,0X01,0X01,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X01,0X01,0X03,0X03,0X03,0X03,0X02,
0X02,0X02,0X01,0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0XC0,0XC0,0XC0,0XE0,0XE0,
0XE0,0XF0,0XF0,0XF8,0X98,0X9C,0X3D,0X7D,0X7D,0X7D,0X7D,0X7B,0X7B,0X03,0X03,0X43,
0XF3,0XF7,0XFF,0XFF,0XFF,0XF7,0X67,0X07,0X07,0X07,0XE7,0XF7,0XF7,0XF7,0XF7,0XF7,
0XE7,0X07,0X07,0X07,0XF7,0XF7,0XFF,0XF7,0XF7,0XF7,0XE7,0X07,0X07,0X77,0X7F,0X7F,
0X7F,0X7F,0X7F,0X7E,0XFE,0X8E,0X9C,0XDC,0XF8,0XF8,0XF0,0XF0,0XE0,0XE0,0XC0,0XC0,
0XC0,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X01,0X03,0X03,0X03,0X03,
0X03,0X03,0X03,0X03,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,
0X07,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X07,0X07,0X07,0X06,
0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X06,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X07,
0X07,0X07,0X03,0X03,0X03,0X03,0X03,0X03,0X03,0X03,0X03,0X03,0X01,0X01,0X01,0X01,
0X01,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
/* 1024 Bytes */
/* End of LCD Pattern */
/* 14/03/2009 03:20:56 */
/* Bitmap Source file : Test.bmp */
const int image_xy[]=
//!0x7F , 0x3F
//!0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X80 ,
//!0XC0 , 0XC0 , 0XC0 , 0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XE0 ,
//!0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XF0 ,
//!0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XC0 , 0XC0 , 0X80 ,
//!0X80 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X00 , 0X00 , 0XFE , 0XFF , 0XFF , 0XFF ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0X0F , 0X07 , 0X03 , 0X03 ,
//!0X01 , 0X01 , 0X01 , 0X01 , 0X01 , 0X01 , 0X01 , 0X01 ,
//!0X01 , 0X01 , 0X01 , 0X01 , 0X03 , 0X03 , 0X07 , 0X0F ,
//!0XFF , 0XFF , 0XFE , 0XF8 , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X00 , 0XFF , 0XFF , 0XFF , 0XFF , 0XFF ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0X7E , 0X7E , 0XD6 , 0XC6 ,
//!0XC6 , 0XD6 , 0XFE , 0XFE , 0XFE , 0XDE , 0XD6 , 0XD6 ,
//!0XD6 , 0X56 , 0X7E , 0X7E , 0X7E , 0X3E , 0X00 , 0X00 ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X80 , 0X80 ,
//!0X80 , 0X80 , 0XC0 , 0XC0 , 0XC0 , 0XC0 , 0XE0 , 0XE0 ,
//!0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XF0 , 0X70 , 0X70 ,
//!0X70 , 0X70 , 0X70 , 0X70 , 0X70 , 0X70 , 0X70 , 0X70 ,
//!0X70 , 0X78 , 0X78 , 0X79 , 0X7F , 0X7F , 0X7F , 0X7F ,
//!0X7F , 0X7F , 0X7F , 0X7F , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0XF8 , 0XF8 , 0XF8 , 0XF8 ,
//!0XF8 , 0XF8 , 0XF8 , 0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XB0 ,
//!0XF0 , 0XF0 , 0XF0 , 0XF0 , 0XF0 , 0X70 , 0X70 , 0XE0 ,
//!0XE0 , 0XE0 , 0XE0 , 0XE0 , 0XC0 , 0XC0 , 0X80 , 0X80 ,
//!0X00 , 0X00 , 0X00 , 0X00 , 0X0F , 0X0F , 0X1F , 0X1F ,
//!0X1F , 0X13 , 0X53 , 0X51 , 0XD1 , 0XC1 , 0X81 , 0X80 ,
//!0XA0 , 0XC0 , 0XC0 , 0XC0 , 0XC0 , 0X40 , 0X40 , 0X40 ,
//!0X40 , 0X40 , 0X40 , 0XC0 , 0XC0 , 0XC0 , 0XC0 , 0XC0 ,
//!0XC0 , 0XC0 , 0XC0 , 0X80 , 0X82 , 0X86 , 0X86 , 0X86 ,
//!0X84 , 0X84 , 0X84 , 0X8C , 0X8C , 0XCC , 0XCC , 0XCC ,
//!0XCC , 0XCC , 0XCC , 0XCC , 0XCC , 0XCC , 0XCC , 0XCC ,
//!0XCC , 0XCC , 0X4C , 0X4E , 0X4E , 0X4E , 0X46 , 0X66 ,
//!0X67 , 0X67 , 0X63 , 0X63 , 0X60 , 0X20 , 0X20 , 0X20 ,
//!0X30 , 0X30 , 0XB0 , 0XB0 , 0X90 , 0X90 , 0X98 , 0X98 ,
//!0XD8 , 0XD8 , 0XDC , 0XDC , 0XDC , 0XFD , 0XFC , 0XFC ,
//!0XFC , 0X7C , 0X7C , 0X79 , 0X79 , 0X7B , 0XF3 , 0XF3 ,
//!0XE7 , 0XCF , 0X8E , 0X9C , 0X38 , 0X70 , 0X60 , 0X60 ,
//!0XC0 , 0XC0 , 0X80 , 0X80 , 0X80 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X01 ,
//!0X01 , 0X01 , 0X03 , 0X03 , 0X07 , 0X07 , 0X0F , 0X1F ,
//!0X1F , 0X3F , 0X3F , 0X7F , 0XFF , 0XFF , 0XFF , 0XFF ,
//!0XFF , 0XFF , 0XFF , 0XFE , 0XFE , 0XFE , 0XFE , 0XFE ,
//!0XFE , 0XFE , 0XFE , 0XFE , 0XFE , 0XFE , 0XFE , 0XFE ,
//!0XFE , 0XFE , 0XFE , 0XFE , 0XFE , 0XFF , 0XFF , 0XFF ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0XFF , 0XFF , 0XFF , 0XFF ,
//!0XFF , 0XFF , 0XFF , 0XFF , 0X7F , 0X3F , 0X3F , 0X1F ,
//!0X0F , 0X0F , 0X07 , 0X03 , 0X01 , 0X01 , 0X00 , 0X00 ,
//!0X01 , 0X01 , 0X01 , 0X03 , 0X03 , 0X03 , 0X03 , 0X02 ,
//!0X02 , 0X02 , 0X01 , 0X01 , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X80 , 0XC0 , 0XC0 , 0XC0 , 0XE0 , 0XE0 ,
//!0XE0 , 0XF0 , 0XF0 , 0XF8 , 0X98 , 0X9C , 0X3D , 0X7D ,
//!0X7D , 0X7D , 0X7D , 0X7B , 0X7B , 0X03 , 0X03 , 0X43 ,
//!0XF3 , 0XF7 , 0XFF , 0XFF , 0XFF , 0XF7 , 0X67 , 0X07 ,
//!0X07 , 0X07 , 0XE7 , 0XF7 , 0XF7 , 0XF7 , 0XF7 , 0XF7 ,
//!0XE7 , 0X07 , 0X07 , 0X07 , 0XF7 , 0XF7 , 0XFF , 0XF7 ,
//!0XF7 , 0XF7 , 0XE7 , 0X07 , 0X07 , 0X77 , 0X7F , 0X7F ,
//!0X7F , 0X7F , 0X7F , 0X7E , 0XFE , 0X8E , 0X9C , 0XDC ,
//!0XF8 , 0XF8 , 0XF0 , 0XF0 , 0XE0 , 0XE0 , 0XC0 , 0XC0 ,
//!0XC0 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 ,
//!0X00 , 0X00 , 0X01 , 0X01 , 0X03 , 0X03 , 0X03 , 0X03 ,
//!0X03 , 0X03 , 0X03 , 0X03 , 0X07 , 0X07 , 0X07 , 0X07 ,
//!0X07 , 0X07 , 0X07 , 0X07 , 0X07 , 0X07 , 0X07 , 0X07 ,
//!0X07 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 ,
//!0X06 , 0X06 , 0X06 , 0X06 , 0X07 , 0X07 , 0X07 , 0X06 ,
//!0X06 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 , 0X06 ,
//!0X07 , 0X07 , 0X03 , 0X03 , 0X03 , 0X03 , 0X03 , 0X03 ,
//!0X03 , 0X03 , 0X03 , 0X03 , 0X01 , 0X01 , 0X01 , 0X01 ,
//!0X01 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 , 0X00 ,
//! 0x40 , 0x20 // This 2 bytes defines the size of BMP for glcd_image_xy() function
//! // You should define it by yourself if your image converter does not
//! // add it by itself.(this image is 64x32 pixels -> 64=0x40, 32=0x20)
//!0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
//!0X00,0X00,0X00,0X00,0X00,0X00,0XF0,0XF0,
//!0XF8,0XF8,0X78,0X3C,0X1C,0X1C,0X1C,0X1C,
//!0X1C,0X1C,0X18,0X38,0XF8,0XF0,0X00,0X00,
//!0X80,0X80,0X80,0X80,0X80,0XC0,0XC0,0XC0,
//!0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0XFF,0XFF,
//!0XFF,0XFF,0X0E,0X0E,0X0E,0X0E,0X0E,0X0E,
//!0X0E,0X0E,0X0E,0X0E,0XFF,0XFF,0XC0,0XC0,
//!0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,0XC0,
//!0XC0,0X80,0X80,0X80,0X00,0X00,0X00,0X00,
//!0X00,0X00,0X00,0X00,0X00,0X00,0X07,0X07,
//!0X07,0X0D,0X0D,0X19,0X19,0X18,0X38,0X78,
//!0X78,0XF8,0XF8,0XF8,0XF8,0XF8,0XFA,0XFA,
//!0XFA,0XFA,0XFA,0XFE,0XFE,0XFE,0XFE,0XFE,
//!0XFE,0XFE,0XFA,0XFB,0XFB,0XFB,0XFC,0XFC,
//!0XFC,0XF4,0XF4,0XFC,0X7F,0X3F,0X1F,0X1F,
//!0X0F,0X0F,0X0F,0X0F,0X1F,0X1F,0X1E,0X1C,
//!0X18,0X18,0X18,0X00,0X00,0X00,0X00,0X00,
//!0X00,0X00,0X00,0X00,0X00,0X18,0X18,0X38,
//!0X3C,0X3C,0X3E,0X3F,0X3F,0X3F,0X3F,0X33,
//!0X3F,0X3F,0X3F,0X3F,0X33,0X3F,0X3F,0X3F,
//!0X3F,0X33,0X3F,0X3F,0X3F,0X3F,0X33,0X3F,
//!0X3F,0X3F,0X3F,0X3E,0X3E,0X1C,0X1C,0X18,
//!0X18,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0x40 , 0x40
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0XC0,0XC0,0XE0,0XE0,0XF0,0XF0,0XF0,0XF0,
0XE0,0XE0,0XE0,0XC0,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0XFE,0XFF,0XFF,0XFF,0X1F,0X07,0X03,0X01,0X01,0X01,
0X01,0X01,0X03,0X07,0XFF,0XFE,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0XFF,0XFF,0XFF,0XFF,0X7E,0XFE,0XD6,0XFE,0XFE,0XD6,
0XD6,0X7E,0X7E,0X3C,0XFF,0XFF,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0X80,0XC0,0XC0,0XE0,0XE0,0XE0,0XF0,0X70,
0X70,0X70,0X70,0X70,0X78,0X78,0X7F,0X7F,0X7F,0X7F,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0XFF,0XFF,0XF8,0XF8,0XF8,0XF8,0XF0,0XF0,0XF0,0XF0,0XF0,0X70,
0XE0,0XE0,0XC0,0XC0,0X80,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X0F,0X1F,0X1F,0X53,0XD1,0XC1,0XA0,0XC0,0XC0,0X40,
0X40,0X40,0XC0,0XC0,0XC0,0XC0,0X82,0X86,0X84,0X8C,0XCC,0XCC,0XCC,0XCC,0XCC,0XCC,
0XCC,0XCE,0X4E,0X46,0X67,0X63,0X60,0X20,0X30,0XB0,0XB0,0X98,0XD8,0XDC,0XDD,0XFD,
0XFC,0X7D,0X79,0XFB,0XE7,0XDE,0X38,0X70,0XC0,0XC0,0X80,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X03,0X07,0X0F,
0X1F,0X7F,0XFF,0XFF,0XFF,0XFF,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,0XFE,
0XFE,0XFE,0XFE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7F,0X3F,0X1F,0X07,0X03,0X01,
0X00,0X00,0X00,0X00,0X01,0X01,0X03,0X03,0X02,0X01,0X00,0X00,0X00,0X00,0X00,0X00,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X80,0XC0,0XE0,
0XF0,0XF0,0XB8,0X7D,0X7D,0X7F,0X7B,0X03,0XF3,0XFF,0XFF,0XF7,0X07,0XF7,0XF7,0XF7,
0XE7,0X07,0XF7,0XFF,0XF7,0XF7,0X07,0X7F,0X7F,0X7F,0XFE,0X9C,0XF8,0XF0,0XE0,0XE0,
0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X01,0X03,0X03,
0X03,0X03,0X07,0X07,0X07,0X07,0X07,0X07,0X07,0X06,0X06,0X06,0X06,0X06,0X07,0X07,
0X06,0X06,0X06,0X06,0X07,0X07,0X07,0X07,0X07,0X07,0X03,0X03,0X03,0X03,0X01,0X01,
//! 0xFF , 0xFF , 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03,
//! 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0xC3 , 0xE3,
//! 0x63 , 0x63 , 0x63 , 0x63 , 0xC3 , 0x83 , 0x03 , 0x03,
//! 0x03 , 0x03 , 0x03 , 0x03 , 0x83 , 0xC3 , 0x63 , 0x33,
//! 0x33 , 0x33 , 0x63 , 0xC3 , 0x03 , 0x03 , 0x03 , 0x03,
//! 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03,
//! 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0x03 , 0xFF , 0xFF,
//! 0xFF , 0xFF , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00,
//! 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x07 , 0x0F,
//! 0x0C , 0x0E , 0x0F , 0x0E , 0x0C , 0x09 , 0x0F , 0x00,
//! 0x80 , 0x80 , 0x80 , 0x03 , 0x0F , 0x0C , 0x08 , 0x0F,
//! 0x0F , 0x04 , 0x0C , 0x0F , 0x0F , 0x00 , 0x00 , 0x00,
//! 0x00 , 0x00 , 0xF0 , 0xF8 , 0xC0 , 0xC0 , 0xFC , 0xF0,
//! 0x00 , 0x00 , 0x00 , 0xD0 , 0xB0 , 0x00 , 0x00 , 0xFC,
//! 0xFE , 0xF8 , 0x00 , 0x00 , 0x00 , 0x00 , 0xFF , 0xFF,
//! 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x00 , 0x03,
//! 0x0F , 0x1E , 0x3C , 0x38 , 0x70 , 0x70 , 0xE0 , 0xE0,
//! 0xE1 , 0xC3 , 0xC7 , 0xC0 , 0xC0 , 0x80 , 0x80 , 0x80,
//! 0x80 , 0xF8 , 0xFC , 0x0E , 0x03 , 0x00 , 0x00 , 0x00,
//! 0x00 , 0x00 , 0x0F , 0x07 , 0x00 , 0x00 , 0x07 , 0x03,
//! 0x02 , 0x00 , 0x00 , 0x0F , 0x1F , 0x00 , 0x00 , 0x00,
//! 0x73 , 0x71 , 0x40 , 0x00 , 0x00 , 0x00 , 0xFF , 0xFF,
//! 0xFF , 0xFF , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0,
//! 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0,
//! 0xC0 , 0xC0 , 0xC0 , 0xC1 , 0xC1 , 0xC1 , 0xC1 , 0xC1,
//! 0xC1 , 0xC1 , 0xC1 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0,
//! 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xC0 , 0xFF , 0xFF
/* 256 Bytes */
#include <16F877A.h>
#fuses XT,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4000000)
#include <Extended_GLCD.c>
char inverse_test_txt[] = "INVERSE IMAGE TEST";
char image_txt[] = "IMAGE";
char box_3D_txt[] = "3D BOX";
char cir_seg_txt[] = "SEGMENT OF A CIRCLE";
char on_xy_txt[] = "ON 'XY' COORDINATE";
char depth2_txt[] = "DEPTH VALUE=2";
char depth3_txt[] = "DEPTH VALUE=3";
void main()
//setup_adc_ports(NO_ANALOGS|VSS_VDD);
//setup_adc(ADC_OFF|ADC_TAD_MUL_0);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
//setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
//setup_comparator(NC_NC_NC_NC);
//setup_vref(FALSE);
glcd_init(ON);
glcd_image(NO);
delay_ms(4000);
//! glcd_bar(2,5,100,5,4,ON);
while (true)
int i;
// FULL SCREEN INVERSE IMAGE TEST
glcd_fillscreen(OFF);
glcd_text57(10,30,inverse_test_txt,1,ON);
delay_ms(3000);
for (i=0;i<=1;++i)
glcd_image(NO);
delay_ms(1500);
glcd_image(YES);
delay_ms(1500);
// IMAGE ON "XY" COORDINATE TEST
glcd_text57(48,22,image_txt,1,ON);
glcd_text57(10,37,on_xy_txt,1,ON);
delay_ms(3000);
glcd_image_xy(0,0,NO);
delay_ms(1500);
glcd_image_xy(64,0,NO);
delay_ms(1500);
glcd_image_xy(0,32,NO);
delay_ms(1500);
glcd_image_xy(64,32,NO);
delay_ms(1500);
glcd_image_xy(32,16,NO);
delay_ms(3000);
// 3D-BOX TEST
glcd_text57(45,22,box_3D_txt,1,ON);
delay_ms(3000);
glcd_text57(25,30,depth2_txt,1,ON);
delay_ms(2000);
glcd_3Dbox(32,16,64,32,2,ON);
delay_ms(3000);
glcd_text57(25,30,depth3_txt,1,ON);
delay_ms(2000);
glcd_3Dbox(32,16,64,32,3,ON);
delay_ms(3000);
// SEGMENT OF A CIRCLE TEST
glcd_text57(7,22,cir_seg_txt,1,ON);
delay_ms(3000);
glcd_circle_seg(64,32,25,0,90,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,90,180,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,180,270,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,270,360,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,0,135,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,90,315,ON);
delay_ms(2000);
glcd_circle_seg(64,32,25,0,360,ON);
delay_ms(2000);
i had problems with only LAT,TRIS & PORT commands...
Re: glcd interface
hello..i want to display any line or circle in glcd ..need pic16f877a interfacing with jhd12864e..code with simulation..thanks advance..
