Single phase inverter
ctag06
Newbie level 3
hello...
i try to simulate single phase inverter using PSpice to compare the result with my hardware. The input is 170Vdc but when i run my work the output voltage is very low...Here is the attachment for my work. I really need someone suggestion or help.
Thanks...
use a P- Channel MOSFET on the top of invertor ans then see the results
switching signal will be complement
Thank you for reply me....
I've try what are you suggested and here i attach the result from my simulation.
for what i've learned before, the output voltage should be from -Vdc to +vdc but the output of my simulation is only at +ve transistion...am i right? correct me if i wrong.
