+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Newbie level 6
    Points: 569, Level: 5
    Join Date
    Mar 2010
    Toronto
    Posts
    13
    Points
    569
    Level
    why pinging works on hub but not on switch
    our prototype can only pinging through hub. it wont work on switch. we use the same network cable, same condition. when pinging through hub, it works very well; when connect it to the switch directly, it stops pinging. Why? What is the potential problem?
    Please anyone has an idea.
    Thanks in advance!
    •   Alt11th March 2010, 22:40
      advertising
  2. #2
    Newbie level 6
    Join Date
    Mar 2010
    Toronto
    Posts
    13
    Points
    569
    Level
    Re: why pinging works on hub but not on switch
    anyone help? Plz,
    I stucked here
    •   Alt12th March 2010, 16:08
      advertising
  3. #3
    Administrator
    Points: 69,157, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,157
    Level
    64
    Blog Entries
    Can you give a little more background info? By prototype do you refer to the ethernet interface as well? Could be something to do with the MAC address and ARP. A hub broadcast packets on all ports, while a switch only routes packets to a port where a particular MAC address is known to exist. ARP is used to correlate an IP Address, assigned by the user to a MAC Address permanently assigned to an interface. Where did you acquire the MAC Address for the prototype?
    •   Alt14th March 2010, 14:23
      advertising
  4. #4
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    When doing ethernet related development, you should be able to use respective tools, e.g. wireshark, to debug the communication.
    ICMP echo request ("Ping") needs to be preceeded by determining the peer's MAC address trough ARP (performed by the TCP/IP stack
    automatically), you should trace the complete action to see, where it fails.
  5. #5
    Member level 4
    Points: 1,164, Level: 7
    Join Date
    Feb 2010
    Hamburg, Germany
    Posts
    71
    Points
    1,164
    Level
    7
    It could be a problem with Auto-MDIX support in your PHY and/or transformer. Have you tried both crossover and straight through cables?
    You might also want to check if autonegotiation is working properly and optionally try to configure all of your hardware manually.
    Regards,
    Chris
