+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 5
    Points: 554, Level: 5
    Join Date
    Feb 2010
    Sri Lanka
    Posts
    10
    Points
    554
    Level
    12V DC to AC converter
    Heyy guys badly need to develop a 12vDc to AC inverter circuit....plz help me thz topic..if u hv circuit diagrams and schematic designs
    •   Alt10th March 2010, 05:51
      advertising
  2. #2
    Newbie level 1
    Points: 498, Level: 4
    Join Date
    Mar 2010
    bhutan
    Posts
    Points
    498
    Level
    hi
    i m college student and our mini-project is to design inverter which convert 12dc to 230ac.plz can u upload circuit diagram.we are 555timer (astable mode),gate drive(both highside and low side and 4 mosfet.
    thank you
    1 members found this post helpful.
    •   Alt14th March 2010, 09:13
      advertising
  3. #3
    Points: 9,782, Level: 23
    Join Date
    Aug 2004
    Egypt
    Posts
    1,185
    Points
    9,782
    Level
    23
    Re: 12V DC to AC converter
    What is your target AC voltage?
    Amr Ali
    •   Alt14th March 2010, 09:57
      advertising
  4. #4
    Advanced Member level 5
    Points: 20,214, Level: 34
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,214
    Level
    34
    HI,
    Maybe you can find some help/idea for your project...
    DC to AC Circuits and Inverter Circuits, www.discovercircuits.com/C/co-dctoac
    Good luck!
    K.
    Inverter 12V to 220V 300W by NE555,2N3055, http://www.elecfree.com/electronic/i...y-ne5552n3055/
  5. #5
    Full Member level 1
    Points: 6,820, Level: 19
    Join Date
    Aug 2006
    Canada,QC
    Posts
    109
    Points
    6,820
    Level
    19
    I really don't recommand this circuit as it outputs square wave. You will end up with harmonics and might affect the working of some wireless device. I am glad to see people trying stuff in electronic, but power converter sould be carefully designed.
    •   Alt16th March 2010, 04:18
      advertising
  6. #6
    Junior Member level 3
    Points: 1,471, Level: 8
    Join Date
    Dec 2009
    KOLKATA
    Posts
    31
    Points
    1,471
    Level
    8
    If, frequency will not your criteria, purchase a transformer of 12 volt, 500mA step down center tap type from 230 Volt. Feed positive of battery to center tap of 12 volt, base Resistance, 1K, 1W, Capacotor 10µF, 63V. Power up and check the output. Mind it, being isolated, Neon tester must not glow on one side, until you ground the other side. Dont forget to use heatsink to your 3055 like power transistor.
    Hope it solve ur problem. The output can give upto 10 Watt depending on the operating frequency.
