which would be cheapest opto coupler for opto isolation
sherazi
Banned
Muscat, Oman, Oman
plz give some cheap but without compromize .... opto-coupler ic
is sharp cheap or ...
There are thousands of different types, all optimized for different purposes. You need to explain more about what it is to be used for and voltages it will be isolating.
For example, do you want: AC or DC isolation, low voltage or high voltage, logic level, low sped, high speed, analog, darlington, transistor, pin diode or triac, zero crossing detect, etc.
Also do you want single isolators or multiple in one package and should it be DIP, wire tails or an SMD package?
Brian.
i am in need of dc low voltages and quad... its just to make sure that the signal is not week enough... can these be used to regenerate a signal i mean that can a fading signal be made fresh by such device eg pc 847
my main task is to isolate some pushbuttons. connected to micro controller... if the push button is at a distance can i use these then... push buttons would have low dc voltages only
