+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Newbie level 6
    Points: 672, Level: 5
    Join Date
    Mar 2010
    Israel
    Posts
    13
    Points
    672
    Level
    Hfss in windows 7
    Hey guys.
    I tried to install Hfss v11 in windows 7.
    I used the compatibility tool to windows XP (sp2) and the installation went smooth.
    The problem is when I try to start the application, I keep getting this annoying error: "Failed to check out license hfss_desktop
    Invalid (inconsistent) license key (FLEXlm Error -8)"
    Any one has an idea how to solve this thing maybe?
    Thanks a lot.
    Assaf.
    •   Alt5th March 2010, 08:05
      advertising
  2. #2
    Newbie level 1
    Points: 489, Level: 4
    Join Date
    Mar 2010
    Scotland
    Posts
    Points
    489
    Level
    Re: Hfss in windows 7
    Quote Originally Posted by asi123
    Hey guys.
    Thanks a lot.
    Assaf.
    I have the same problem - did you find a solution ?
  3. #3
    Full Member level 6
    Points: 4,488, Level: 15
    snkhan's Avatar
    Join Date
    Oct 2005
    Gods place
    Posts
    324
    Points
    4,488
    Level
    15
    Need help to solve Hfss license error in windows 7
    I tired HFSS12 with Windows 7 and same error
    FLEXlm Error -8
  4. #4
    Newbie level 3
    Points: 404, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    404
    Level
    Re: Need help to solve Hfss license error in windows 7
    Same problem here with v13.0 and Win7.
    1 members found this post helpful.
  5. #5
    Member level 4
    Points: 2,073, Level: 10
    Join Date
    Oct 2005
    Posts
    78
    Points
    2,073
    Level
    10
    Shame on you!
    We are talking about legally purchased software. There's a bug preventing access to FLEXLM server.
    •   Alt28th August 2012, 00:38
      advertising
  6. #6
    Member level 4
    Join Date
    Oct 2005
    Posts
    78
    Points
    2,073
    Level
    10
    seems like I was trying to install some crippled distributive that time.
    After I made last post I tried some other DVD of v13 laying around in our lab and everything went smoothly. So, I can only recommend to try another version/build.
  7. #7
    volker_muehlhaus
    From the FlexLM user's guide:
    -8 Invalid (inconsistent) license key or signature.
    The license key/signature and data for the feature do not match. This usually happens when a license file has been altered.
  8. #8
    Member level 4
    Join Date
    Oct 2005
    Posts
    78
    Points
    2,073
    Level
    10
    Yes. But actually the same thing can happen upon start-up when there are problems with license server(ghost users, hangup etc.). And actually in my case there was some kind of (?)obsolete(?) distributive. So, I believe, that was a version conflict.
    "license file has been altered"
    In license-server case the local file is just a text file with server's address
  9. #9
    volker_muehlhaus
    Quote Originally Posted by Andryuha View Post
    Really? That's interesting.
    For copy protection, the FlexLM license file also has an encrypted section. You will get the above error if you edit the Host-ID in the license file, and the encrypted section does not match that Host-ID.
    edit: or do you mean the port@host syntax, like 1234@mylicsvr.ibm.com ?
    •   Alt3rd October 2012, 15:07
      advertising
  10. #10
    Member level 4
    Join Date
    Oct 2005
    Posts
    78
    Points
    2,073
    Level
    10
    sure it is
    Anyone is free to textedit that redirect.lic file for HFSS v13 under Win32/64.
    We don't have any signatures in our HFSS client-server setup in our lab. We start installation, enter the address and the plain text file is created. Then we can fix it, for example, to change ports, or use another server.
  11. #11
    volker_muehlhaus
    Sure. In the floating license case that redirects to the license server, you can edit the host name.
    However the Host ID in the license file can not be edited, of course. This will lead to the Invalid (inconsistent) license key or signature error message.
