difference between simulated and measurement results in UWB
Leilon
Member level 5
Hi all,
I designed a UWB antenna and implemented on fr4 substrate, but my measurement result is not very good, what's happening? what's solution?
I uploaded my result.
thanks
to me its damn good!
biff44, why?! it's cheap
hi,
Is you simulate the gainand radiation pattern??
may be this result correct for s11 only
i think you should get better result for all the s11,gain,directivity and radiation pattern then you can measure and compar your results
Thank
Eng.M.hassanien
Re: difference between simulated and measurement results in
It IS cheap. But to be wondering why there is a small discrepancy between measured and predicted data at 10 GHz on an FR4 board is.....asking too much?
