+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Member level 2
    Points: 3,511, Level: 13
    Join Date
    Dec 2002
    Posts
    52
    Points
    3,511
    Level
    13
    op amp attenuator
    Hi friends;
    I have a question about using op amp as attenuator.
    Can i use op amps for Gain<1.
    Bests.
  2. #2
    Member level 1
    Points: 1,676, Level: 9
    Join Date
    Apr 2004
    Posts
    34
    Points
    1,676
    Level
    9
    op amp gain less than 1
    Yes ofcourse yous in inverting mode if the feed back resistor is less than the input resistor
    Gain =-Rf/Ri
    and you can add an other unity inver to get non-invering gain <1
    •   Alt12th April 2004, 08:53
      advertising
  3. #3
    Junior Member level 1
    Points: 1,722, Level: 9
    Join Date
    Mar 2004
    Posts
    15
    Points
    1,722
    Level
    9
    opamp attenuator
    Dear friend,
    Yes ofcourse you can use the amplifier as a attenutor(gain<1) but be carefull about stability. What most of the people used to do is they check the stability of apmifier in unity gain mode, that would be the worst case of stability in most of the cases where the gain is more than one , This may not be true in this case.
    •   Alt12th April 2004, 09:30
      advertising
  4. #4
    Member level 1
    Join Date
    Apr 2004
    Posts
    34
    Points
    1,676
    Level
    9
    op-amp attenuator
    stabilty depends on frequency as will.
    •   Alt12th April 2004, 09:48
      advertising
  5. #5
    Member level 2
    Join Date
    Dec 2002
    Posts
    52
    Points
    3,511
    Level
    13
    op amp gain < 1
    Dear friends;
    I was sure thar i can use the op amp as attenuator.
    But i am intersting that khow what is the specs for using op amp as the attenuator (1/20) for 10MHZ input?
    Can i use AD844 or simular Op amp for this reason?
    I will be happy if you can help me.
    Bests.
  6. #6
    Member level 1
    Join Date
    Apr 2004
    Posts
    34
    Points
    1,676
    Level
    9
    less than unity gain op amp
    At 10 Mhz opamp as attenuater is not aggod choice. you should use an other technique. although AD844 might give you some gain also if you want at 10Mhz
  7. #7
    Full Member level 3
    Points: 2,788, Level: 12
    Join Date
    Dec 2001
    China
    Posts
    166
    Points
    2,788
    Level
    12
    using an op amp as an attenuator
    of course:
    it will perform to change impedance in some case.
  8. #8
    Member level 1
    Points: 1,907, Level: 10
    Join Date
    Feb 2004
    Posts
    36
    Points
    1,907
    Level
    10
    attenuator using op amp
    Why dont you use a simple divider network - the op amps are not so stable for gains lower then 1 !
    •   Alt12th April 2004, 15:24
      advertising
  9. #9
    Full Member level 1
    Points: 3,106, Level: 13
    Join Date
    Dec 2001
    Posts
    97
    Points
    3,106
    Level
    13
    op amp attenuators
    Ignore the replies about stability issues with NI amplifiers having a gain less than one.
    In this case the stability will be determined by the noise gain (from non-inverting input to output) which will approach 1 (from above) as the inverting gain is decreased towards zero.
  10. #10
    Member level 1
    Join Date
    Feb 2004
    Posts
    36
    Points
    1,907
    Level
    10
    non inverting op amp gain less than 1
    OK I'll reply once why dont you use simple divider network followed by an OP AMP unity gain follower?
  11. #11
    Full Member level 1
    Join Date
    Dec 2001
    Posts
    97
    Points
    3,106
    Level
    13
    attenuator 18db opamp
    Because in most cases there will be no advantage in doing so. Remember that it is usually preferable to operate operational amplifiers in an inverting mode since distortion due to common-mode gain is minimised.
