how to renumber the pin no in allegro
binu G
Advanced Member level 2
Bangalore
edit pin numbers in allegro
can any one help me how i can renumber the footprint pad numbers.
thanks
binu george
renumber pins allegro
Try Edit-Text 8)
allegro package renumbering
i have seen in apd it is possible but not in allegro
any other way text edit too failed
binu g
I am surprised that Edit>Text failed. I have done it and worked ok.
Remember though you cannot have identical pin numbers.
Good luck.
IN ALLEGRO SYMBOL EDITOR, USING EDIT TEXT YOU CAN MODIFY PINNUMBER
select the edit >text.
then click on the pins you want to renumber that will do.
Ricky
