+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 2
    Points: 2,444, Level: 11
    Join Date
    Mar 2006
    Rome
    Posts
    51
    Points
    2,444
    Level
    11
    help: how to make a Drill file (gerber) from a *.dxf file?
    I need to extrapolate a DRILL file from a dxf file
    I use Linkcad4 and I can make gerber files, but I don't understand how to make a Drill file
    thanks in advance
    •   Alt9th February 2010, 10:53
      advertising
  2. #2
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,951
    Points
    241,624
    Level
    100
    Does the dxf file contain explicite pads or drill positions.? Than it's easy. Otherwise you have to extract pads from the artwork data or insert drill positions manually.
    1 members found this post helpful.
    •   Alt9th February 2010, 13:19
      advertising
  3. #3
    Member level 2
    Join Date
    Mar 2006
    Rome
    Posts
    51
    Points
    2,444
    Level
    11
    Re: help: how to make a Drill file (gerber) from a *.dxf fil
    The file contains a layer for the holes (vias), but i don't understand how linkcad can extract the file *.DRILL
