How to include header file in VHDL module
raghava
Hi all,
Could you tell me how to include a header (.h) file in VHDL.
In verilog we does like this.
entity X
end entity;
`include "rtl/def_HarrisCorner.h"
How it will achieved in VHDL module. And where exactly it will be done the VHDL file.
Any help is appreciated.
There's no header file option in VHDL. To make project wide assignments of constants and define types or functions, you can use a package.
All packages are compiled to the library work by default.
package DEFS is
  CONSTANT MAJOR_VERSION: INTEGER := 0;
  CONSTANT MINOR_VERSION: INTEGER := 22;
  CONSTANT MAXREG: integer := 52;
  TYPE REGS_TYPE is array (0 to MAXREG) of STD_LOGIC_VECTOR(15 downto 0);
  FUNCTION opndrn(inp: std_logic) return std_logic;
end package DEFS;
package body DEFS is
FUNCTION opndrn(inp: std_logic) return std_logic IS
 begin
    CASE INP is
      WHEN '0' => return '0';
      WHEN OTHERS => return 'Z';
    END CASE;
 end;
end package body DEFS;
to include the package in a compilation unit
LIBRARY work;
USE work.defs.all;
As an interesting feature, the types defined in a package can be referenced in an entity port definition.
    raghava
Thanks for answer. Its working!
Regards,
Hi all,
Thanks for your responses.
Added after 1 hours 13 minutes:
Hi all,
If there are more no of constants in def file, can I keep them in seperate file and include. If so how???
Anybody could help me.
