+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 6
    Points: 1,914, Level: 10
    Join Date
    Jul 2002
    Posts
    14
    Points
    1,914
    Level
    10
    measuring 3 phase voltage
    Are anyone have good and simple schematic for measuring 3-phase mains voltage and current (380 V) with current and voltage transformers. I need some sort of amplifiers and filters for that, but I could not find any detailed and useful schematic.
    Thanks!
    •   Alt7th April 2004, 16:26
      advertising
  2. #2
    Super Member
    Points: 3,669, Level: 14
    Join Date
    Jan 2002
    Posts
    198
    Points
    3,669
    Level
    14
    how to measure 3 phase voltage
    You can use ADE7754 or the newest one ADE7758 powermeter that send on SPI serial, all data regarding the 3 phase powerlines (voltage, current, phase, power, energy etc)
  3. #3
    Full Member level 6
    Points: 4,747, Level: 16
    Join Date
    Oct 2002
    India
    Posts
    324
    Points
    4,747
    Level
    16
    3 phase mains
    8) if you have to measure power factor, voltage etc. for R&D purpose
    FLUKE43B is best but price 3000$ approx.
    •   Alt8th April 2004, 17:20
      advertising
  4. #4
    Full Member level 3
    Points: 2,998, Level: 12
    Join Date
    Feb 2002
    Posts
    175
    Points
    2,998
    Level
    12
    measuring 3 phase current
    TI is developing several applications based on the MSP430 family for the measurement of electric power.
    They offers 2 solutions :
    MSP430FE427 includes on board a DSP cell for the calculus of the energy but is available only for single phase applications.
    For three phase applications they suggest the use of a general purpose MSP430F449.
    See the attachements for details
    •   Alt8th April 2004, 17:43
      advertising
  5. #5
    Member level 1
    Points: 1,978, Level: 10
    Join Date
    Mar 2004
    Posts
    37
    Points
    1,978
    Level
    10
    measuring three phase voltage
    You can use chips from :analog devices ADEXXXX chips. And also Sames Micro. Electronics produces like these chips
  6. #6
    Newbie level 1
    Points: 1,314, Level: 8
    Join Date
    Aug 2005
    Posts
    Points
    1,314
    Level
    8
    measuring mains voltage
    Quote Originally Posted by marie65
    Hi.
    I'm using ADE7754 wşth PIC 18f458.But I have a serious problem.
    I can read voltages of the three phases but ADE7754 only measures the period of phaze A.So if I don't plug phase A , the period of phaze B and phaze C are all 0.But in fact they are 50Hz.
    Anyone has an idea?
    I think it's a initialization problem but could not solve yet.
    if you know pls email me
    tguclu@savronik.com.tr
    •   Alt23rd August 2005, 15:01
      advertising
  7. #7
    Junior Member level 3
    Points: 1,173, Level: 7
    Join Date
    Jul 2007
    Posts
    27
    Points
    1,173
    Level
    7
    measuring 3 phase power
    Hi.
    I'm using ADE7754 with PIC 16F876.But I have many problems.
    I can t read nothing . I use the module MSSP of the PIC, and use DIN,DOUT and SCLK with Pull up resistance. I try know the temperature of the PIC,, but sends me 0.
    Can you help me please??
  8. #8
    Advanced Member level 5
    Points: 36,491, Level: 46
    flatulent's Avatar
    Join Date
    Jul 2002
    Middle Earth
    Posts
    4,629
    Points
    36,491
    Level
    46
    three phase mains voltages
    In situations like this it best to start with a known load and use a hand held VOM or DVM to measure the outputs of the sensing transformers and do hand calculations. Next have your automated data recording system measure the transformer outputs and compare the readings with your hand held insturment readings. Once the automatic collector is able to match your readings then compare the calculations of the automatic system with your hand calculations.
  9. #9
    Join Date
    Jul 2007
    Posts
    27
    Points
    1,173
    Level
    7
    measuring 3-phase current
    Hello friends ,, I´ m working with the ADE7754, and I have a problem with the reading
    of vrms registers. I read between 214V and 224V and the input is 220V . The error is
    too big 3.6% approximetly. I want to know if you have the same numbers..
    I wrote (-5) in AVRMSOS and read with zero crossing detection,, do you use pull up
    with the IRQ??
    thanks..
  10. #10
    Newbie level 3
    Points: 864, Level: 6
    Join Date
    Mar 2008
    Posts
    Points
    864
    Level
    mains voltage measurement
    I have tried to work with this chip ADE7758 but have failed in each attempt. I tried to make chip talk with the MC68HC11, PIC28, & FPGA. MC68HC11 was the worst one, where the programing was the matter. PIC28 - I fried this one the first time. And the FPGA - I did succeeded with the programing, but here the chip was not getting caliburated with the output, where I am getting repeatedly 'FFFF' in the 7segment output.
    Hence, I request any of them who know or have done their project to come forward and help, regarding this failur that I have faced.
    I will appreciate your help, feed back or even I will buy/pay for your time or the whole project.
    Feel free to email at pm_kle@yahoo.co.uk
    thanks
