+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 749, Level: 5
    Join Date
    Sep 2009
    Viet Nam
    Posts
    15
    Points
    749
    Level
    Problem with Converting voltage to frequency !
    Hi all . I have a problem with Lm331. I connect Fout pin in Lm331 to B pin 2n2222 transistor. And i really want to know transistor 2N2222 can work on off with frequency about 1kHz. Because i want to measure voltage Dc by counting frequency use Microcontroller 8051! Thank !
    •   Alt29th January 2010, 13:29
      advertising
  2. #2
    Super Moderator
    Points: 241,686, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,965
    Points
    241,686
    Level
    100
    It surely can. But there's no reason to use a transistor in this place. Just connect Fout to the 8051, with a pull-up resistor as suggested in the datasheet.
    •   Alt29th January 2010, 14:20
      advertising
  3. #3
    Member level 1
    Points: 757, Level: 6
    Join Date
    Jan 2010
    Paksitan
    Posts
    34
    Points
    757
    Level
    Re: Problem with Converting voltage to frequency !
    XR4151 is Voltage to frequency and frequency to voltage converter IC u can use this ic 4 yr work
    •   Alt29th January 2010, 14:44
      advertising
  4. #4
    Advanced Member level 5
    Points: 20,222, Level: 34
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,222
    Level
    34
    LM331 is similar with them, hase both functionality too...
    K.
    Added after 2 hours 23 minutes:
    HI,
    Tnx & check LM331 datasheet from National-is more detailed & has some ciruits-ideas too.
    K.
    1 members found this post helpful.
  5. #5
    Newbie level 2
    Points: 515, Level: 4
    Join Date
    Jan 2010
    viet nam
    Posts
    Points
    515
    Level
    hi1
    i have a circrit with lm331&89s52 as file:
    http://www.mediafire.com/?myczt5dom2w
    please check for me!
    thanks!
    •   Alt30th January 2010, 02:16
      advertising
  6. #6
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,222
    Level
    34
    Hi dryvu,
    Sorry, me isnt possible to download your file!
    Firefox,Opera & IntExplorer, all 3 are not enough to get it...
    Pls send it me as PM & attached file or put it public on...
    K.
