please check my program code (serial communication)
katsmiley
mumbai
hey guys plz help me out.....here i have done program for serial transmition..i am using keil compiler...my problem is i can not see string"ATKT" in the serial window.i am sending it char by char using putchar ....whai is wrong inthis??plz help..........
#include<stdio.h>
#include <REG51.H>
void send(unsigned char []);
void delay();
void serialint(void);
unsigned char prati[]="ATKT";
void main()
serialint();
while(1)
send(prati);
delay();
SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */
TMOD |= 0x21; /* TMOD: timer 1, mode 2, 8-bit reload */
TH1 = 0xf3; /* TH1: reload value for 2400 baud */
TR1 = 1; /* TR1: timer 1 run */
TI = 1;
void delay(void)
TH0=0XEE;
TL0=0XE0;
TR0=1;
while(!TF0);
TF0=0;
void send(unsigned char *p)
int val=0;
while(*p!='\n')
val=*p;
putchar(val);
delay();
p++;
:cry::cry:
Re: serial communication
Try this code.....
#include"reg51f.h"
void DelayMs(unsigned int period)
unsigned int i,j,k=0;
period<<=1;
for(i=0;i<period;i++)
for(j=0;j<0x14;j++)
k++;
void init_serial()
TMOD = 0x20;
TH1 = 0xFD; // For 9600 Baud Rate
SCON = 0x50;
TR1 = 1;
void send_char(unsigned char ch)
SBUF = ch;
while( !TI );
TI = 0;
void send(unsigned char *temp)
while(*temp)
send_char(*temp);
DelayMs(10);
temp++ ;
void main()
init_serial();
send("HELLO WORLD") ;
while(1);
If you want to use serial communication with serial Interrupt
Gurpreet Singh
www.embeddedcraft.org
thnx for ur reply....but tell me what is wrong in my code?in my code i want to use putchar to see its working.....so can anybody tel me what is wrong?can anybody modify my code???
come on!! plz tel me......
I tested your program on Keil and found it working fine. I do see the ATKT for the first four characters.
    katsmiley
thnx a lot....really its workin????but i cant see anything ......what will be the reason??
what serial window you were looking at.
I used the generic simulator for 8052 in Keil and the serial 1 window.
I do see ATKT and then some non-displayable characters values. I think your string is not properly null terminated.
I think this is the mistake..
initially you have declared the parameter as unsigned char and then as a pointer.
IMO it should be
void send(unsigned char *p);
//your code;
:D
