+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Member level 1
    Points: 727, Level: 5
    Join Date
    Jan 2010
    UK
    Posts
    33
    Points
    727
    Level
    ASCII converter
    Hi all,
    I am wondering where I could find some information about binary to ASCII converter in VHDL???
  2. #2
    Advanced Member level 2
    Points: 11,112, Level: 25
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    binary to ASCII converter in VHDL needed
    There is not such thing as ASCII in VHDL, what do you want to do? Implement printf?
    1 members found this post helpful.
  3. #3
    Member level 1
    Join Date
    Jan 2010
    UK
    Posts
    33
    Points
    727
    Level
    Re: binary to ASCII converter in VHDL needed
    My FPGA will get some data, and I would like to transfer those data from binary to ASCII before I send them to a PC.
    •   Alt14th January 2010, 09:42
      advertising
  4. #4
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    Ok, once again it is not clear, what do you mean by converting to ASCII, ASCII is binary data. o you want to convert integer values to ASCII value of it or something similar? Are you trying to connect your FPGA to a computer terminal?
    Your question doesn't make sense if you don't clarify it more.
  5. #5
    Member level 1
    Join Date
    Jan 2010
    UK
    Posts
    33
    Points
    727
    Level
    Sorry about that.
    I use FPGA (Spartan-3) to connect to a PC via USB port.
    I would like to transfer binary values to ASCII values, because computers can read ASCII.
    And then I can use software to read or analyse those ASCII values.
    I don't know if it's clear.
    •   Alt14th January 2010, 12:48
      advertising
  6. #6
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    This is really getting nowhere. Do you know ANYTHING about USB or FPGA at all?
    First of all, Using USB to communicate between an FPGA and a PC is like trying to fly a 747 in order to go to your friends home next door.
    USB is complicated, difficult and complex protocol and in NO WAY it is communicating in ASCII, unless you have a special device/program that does this for you.
    If you use a serial port, then you can use a simple terminal program on the PC and a simple rs232 IP on the FPGA to make the communication, then you can write a simple code to convert your binary data to HEX values in ASCII, this should be simple enough to do.
  7. #7
    Member level 1
    Join Date
    Jan 2010
    UK
    Posts
    33
    Points
    727
    Level
    I use Spartan-3, and the chip controls USB port is CP2101.
    Actually, it uses serial port's concept to do communication.
    Using it, I will need to install CP2101's driver, then connect with a PC and it will be shown as a virtual COM port.
    So in this case, I just need to build a RS232 UART, and I can connect the FPGA with a PC via USB port.
    •   Alt15th January 2010, 11:30
      advertising
  8. #8
    Join Date
    Oct 2004
    Nice, France
    Posts
    589
    Points
    11,112
    Level
    25
    Yes, that is the case, but you need to write a controller to manage the data communication via RS232 on your FPGA.
  9. #9
    Junior Member level 2
    Points: 634, Level: 5
    Join Date
    Apr 2010
    Maribor - Slovenia
    Posts
    23
    Points
    634
    Level
    Hello. I have similar problem. I need to send data from FPGA to PC.
    For example..
    I have:
    std_logic_vector (7 downto0) = 11100011; -- represent value 153
    I need to send 1 (49) , 5 (53) and 3 (51) because RS232 is ASCII coded!
    Can someone help me how to convert std_logic_vector TO ASCII values.
    code can be in VHDL or Verilog.
    Thanks a lot.
  10. #10
    Advanced Member level 5
    Points: 35,870, Level: 46
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    As posted before, ASCII is binary. There is no conversion at all. A std logic vector is just a collection of bits. The data inside the std_logic_vector could be an integer, it could be ascii, it could be BCD, it could be whatever you want it to be. Its just a collection of bits.
    Is this data not already ascii? what encoding scheme does it use?
  11. #11
    Join Date
    Apr 2010
    Maribor - Slovenia
    Posts
    23
    Points
    634
    Level
    OK. I will refraze my question.
    I need function in vhdl or Verilog vith:
    RegisterIN : IN std_logic_vector (7 downto0);
    Numb1 : OUT std_logic_vector(3 downto 0);
    Numb2 : OUT std_logic_vector(3 downto 0);
    Numb3 : OUT std_logic_vector(3 downto 0);
    IF RegisterIN is 10011001 --153 in Dec,
    Numb1 must be 0001 -as 1 in dec
    Numb2 must be 0101 -as 5 in dec
    Numb3 must be 0011 -as 3 in dec
    This is IT !!!!
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,563
    Points
    35,870
    Level
    46
    You're going to need a divider to work out all of the different base 10 values you need. These are expensive bits of hardware.Then using that it should be straight forward to extract 1, 5 and 3.
  13. #13
    Join Date
    Apr 2010
    Maribor - Slovenia
    Posts
    23
    Points
    634
    Level
    Yes, you are right.
    I am looking for the alternative solution if it exists. But i think I will solve this problem on PC. I will just send RegisterIN as it is and decode it in VB.
    Thanks anyway :)
  14. #14
    Member level 2
    Points: 1,318, Level: 8
    Join Date
    Jul 2010
    India
    Posts
    49
    Points
    1,318
    Level
    8
    if you want to send ASCII in binary form you had to convert first the binary.. by detecting your binary no. like either it is a integer (0 to 9) or alphabet (A to Z) or (a to z) and then adding accordingly 30(hex) (0011 0000) for 0 to 9 of your detected binary then 41(hex) for A to Z and rest all like that.
    but first you had break the incoming data bits, analyze them, process them, and then concatenate.. i hope this helps you..!!
    Jimmy
    "That man will win the other day, who loses with smile....."
  15. #15
    Advanced Member level 3
    Points: 5,700, Level: 17
    Join Date
    Jul 2010
    Posts
    923
    Points
    5,700
    Level
    17
    basically, it sounds like they are asking for a VHDL itoa block. The conversion is easiest on the PC side, as you've mentioned. raw binary is undecipherable with standard terminal programs. hexadecimal can be useful for numeric data that needs to be printed by a standard terminal, and base64 works for arbitrary data that needs to be printed by a standard terminal. If you don't ever need to look at the data using a standard terminal, then binary is a good choice, as it is link efficient.
  16. #16
    Join Date
    Apr 2010
    Maribor - Slovenia
    Posts
    23
    Points
    634
    Level
    Thanks a lot. I have allready done it in visual basic.
    But if anyone know another way, how to break bits apart let me know. Devide with 10 and save number as integer is not a good idea for FPGA, it require to many recorses as TrickyDicky said.
  17. #17
    Newbie level 1
    Points: 380, Level: 4
    Join Date
    Nov 2010
    Posts
    Points
    380
    Level
    Hi. The easiest way to do "byte" to "bcd expansion" is a simple case statement with all 255 options explicitlyy defined. The operation is then a basic boolean 8-bit lut function per each output bit
    NOTE: you will need to specify a "no rom extract" synthesis attribute to stop quartus or xst inferring a ROM block.
    the following will reduce to a 31 LUT implementation in the FPGA a V5,S6,V6,Arria or Stratix etc....
    e.g.
    case (in_byte) is
    when x"00" => val <= X"000";
    when x"FE" => val <= X"254";
    when others => val <= X"255";
    voila, nice compact expander.
  18. #18
    Administrator
    Points: 37,998, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
    Quote Originally Posted by ZigaM View Post
    This is IT !!!!
    I have done something similar in a function for avr to convert a long unsigned integer to a string.
    You make subtractions instead of division,
    you make a loop to subtract 100 from the input number and after each subtraction you increase the first digit of the output by 1 until the number is lower than 100
    then you do the same using 10 (increasing the second output digit) and 1 (increasing the third output digit) until the number is 0.
    234 - 100 output 100 (Numb1=1, Numb2=0, Numb3=0)
    134 - 100 output 200
    034 is lower than 100
    034 - 10 output 210
    024 - 10 output 220
    014 - 10 output 230
    004 is lower than 10
    004 - 1 output 231
    003 - 1 output 232
    002 - 1 output 233
    001 - 1 output 234 (Numb1=2, Numb2=3, Numb3=4)
    000 stop
    i don't know if this takes many resources in VHDL because i haven't tried it but is can be done.
    Alex
    •   Alt24th November 2010, 19:10
      advertising
  19. #19
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
  20. #20
    Administrator
    Achievements:
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,998
    Level
    47
    Blog Entries
    I found another article,it is the same method but it is easier to understand and has nice examples
    Binary to BCD Converter
    and pdf version http://www.ee.duke.edu/~dwyer/course..._Converter.pdf
    Alex
