+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Full Member level 3
    Points: 2,465, Level: 11
    Achievements:
    7 years registered
    adnan_merter's Avatar
    Join Date
    Jan 2008
    The most beautiful city of the world
    Posts
    153
    Points
    2,465
    Level
    11
    counting problem
    i am trying to design a logic circuit to drive a unipolar step motor. when i simulate my circuit in ewb, it works properly and without any problem, but when i create my circuit with ICs, 7473 counts just a few secon then stops counting.
    i couldnt find the problem i just provide it 130 hz input signal. what could be the problem?
    or do you know a logic control circuit for step motor (i know it is much easier to do this with pics and comps but this is a homework and must be done:D)
    thanx
    •   Alt9th January 2010, 20:18
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,214, Level: 34
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,214
    Level
    34
    counting problem
    can you have an oscilloscope? Check the signals on your counter...
    Maybe is an thermal effect_can it after some cooling pause repeatedly function , or is it dead?
    Are your input pulses not higher as supply voltage, & do you have real GNDs on the 7473s gnd-pin?
    Maybe your motor gives on the counter big transients = t will be rash killed:-(
    K.
    •   Alt9th January 2010, 20:35
      advertising
  3. #3
    Member level 2
    Points: 830, Level: 6
    Join Date
    Dec 2009
    USA
    Posts
    46
    Points
    830
    Level
    Re: counting problem
    I use the http://www.teahlab.com/ online circuit board to simulate my circuits before implementing them with IC because it tends to reveal the funny conditions. Can you upload a snapshot of your circuit?
    ref: http://www.teahlab.com/; click on "Circuit Board" and then scroll down to view board.
    I doubt the issue is heat related since this circuit does not sound intense.
    •   Alt10th January 2010, 03:14
      advertising
  4. #4
    Banned
    Points: 5,790, Level: 18
    Join Date
    Jun 2005
    scotland uk
    Posts
    646
    Points
    5,790
    Level
    18
    sounds like the usual ewb problem with mixed mode ic
    better you 'find' proteus vsm
    and retry your paradym in that
    youll find it works
    ewb is rubbish for any type of simulation
    im not sure that company every got off mars???
    for pcb design they "were" ok
    for simulation well thats a decade ago now
    use a modern tool
  5. #5
    Achievements:
    7 years registered
    Join Date
    Apr 2008
    EU
    Posts
    2,328
    Points
    20,214
    Level
    34
    counting problem
    Hi peoples,
    He has the problem with realized circuit and not during simulation...
    K.
