+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Full Member level 1
    Points: 2,886, Level: 12
    Join Date
    Aug 2002
    malaysia
    Posts
    111
    Points
    2,886
    Level
    12
    proteus 7 compatibility on windows 7
    Hi...
    I have try install the proteus 7.6 under windows 7 all look ok no problem but when using the isis the component cannot place. and if you open the project example you can see the component but if you clik on the windows all gone....
    Pls help , I try search on the windows7 compatibility but cannot find the info.
  2. #2
    Full Member level 1
    Join Date
    Aug 2002
    malaysia
    Posts
    111
    Points
    2,886
    Level
    12
    Re: proteus 7 compatibility on windows 7
    To anybody how have the same problem pls help me...on this.
    2 members found this post helpful.
  3. #3
    Full Member level 6
    Points: 6,609, Level: 19
    hugo's Avatar
    Join Date
    Jan 2000
    canada
    Posts
    323
    Points
    6,609
    Level
    19
    As far as I know Proteus 7.5 is Vista compatible and 7.6 is Windows 7 compatible.
    If you have a legal key then you can ask Labcenter for support, otherwise try to contact the cracker ... :D
    1 members found this post helpful.
    •   Alt31st December 2009, 18:14
      advertising
  4. #4
    Full Member level 1
    Join Date
    Aug 2002
    malaysia
    Posts
    111
    Points
    2,886
    Level
    12
    I already try install in windows xp all ok , dont have any windows 7 problem
    •   Alt31st December 2009, 21:33
      advertising
  5. #5
    Full Member level 1
    Join Date
    Aug 2002
    malaysia
    Posts
    111
    Points
    2,886
    Level
    12
    Thank Hugo, from you info I find out that the proteus 7.6 can run under win 7, and the problem is license. My proteus can run and ready to simulate the PIC24F for my project.
  6. #6
    Newbie level 3
    Points: 413, Level: 4
    Join Date
    Sep 2010
    Posts
    Points
    413
    Level
    Quote Originally Posted by shahrol_hisham View Post
    hi..i have the same problem with my proteus...
    do u mean to change my license key is the answer to the problem?..pls help...tnx
    •   Alt24th September 2010, 10:55
      advertising
  7. #7
    Junior Member level 3
    Points: 645, Level: 5
    Eng_Bandar's Avatar
    Join Date
    Aug 2010
    Posts
    31
    Points
    645
    Level
    Is find any demo version for proteus compatable with Windows 7 64bit ? I treid proteus 7 demo in labcenter's site but not work with my operating system
  8. #8
    Member level 4
    Points: 1,607, Level: 9
    Join Date
    Jul 2006
    Posts
    75
    Points
    1,607
    Level
    9
    well for my solution is i put a virtual to my window 7...
    and it works normally even some other PCB or software simulation like saber and PADS.
    try oracle virtual box, that is open-source or XP mode in Windows 7
  9. #9
    Junior Member level 2
    Points: 1,175, Level: 7
    Join Date
    Mar 2010
    pakistan
    Posts
    24
    Points
    1,175
    Level
    7
    try to see the system time and date
    is that is ok
    i feel problem with time and date also with Proteus
  10. #10
    Full Member level 4
    Points: 3,390, Level: 13
    Join Date
    Aug 2005
    Romania
    Posts
    221
    Points
    3,390
    Level
    13
    I have Win 7 32 bit on laptop and Proteus 7.7 run perfect. No problem.
  11. #11
    Full Member level 1
    Points: 1,519, Level: 8
    Join Date
    Dec 2010
    Cairo, Egypt, Egypt
    Posts
    98
    Points
    1,519
    Level
    8
    i have the problem near this Proteus7.6 it work ok but it Autoclose when i use it if any solution for this problem iuse xp not win7.
  12. #12
    Newbie level 1
    Points: 416, Level: 4
    Join Date
    Aug 2010
    Posts
    Points
    416
    Level
    Quote Originally Posted by electronicus View Post
    plz tel me d link from where i can download proteus 7.7..
    em using win 7 64 bit
  13. #13
    Administrator
    Points: 37,969, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    37,969
    Level
    47
    Blog Entries
    Quote Originally Posted by turrab View Post
    em using win 7
    Labcenter Electronics - Professional PCB Design and Simulation Software
    And don't use SMS abbreviations in yous posts.
    Alex
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
  14. #14
    Newbie level 5
    Points: 246, Level: 2
    Join Date
    Oct 2011
    Posts
    9
    Points
    246
    Level
    i used to meet the problem like u. and solution is:
    1- you can uninstall the program proteus, then try to set up again.
    2- if it still have problem u can uninstall again then set up again. before set up u click on file set up and right click then choose property. on the compatibility tab after that check on run this program in compatibility mode for: box and choose window xp service pack 3. then click ok
    after that u can install it following guide in program.
    •   Alt16th October 2011, 13:04
      advertising
  15. #15
    Points: 12,053, Level: 26
    Achievements:
    thannara123's Avatar
    Join Date
    Jan 2010
    Nedumkandam, India, India
    Posts
    1,404
    Points
    12,053
    Level
    26
    Blog Entries
    Change the Comparability mode to Xp3 or Xp2 before installing the Proteus
    I Respect You
