George.M
Newbie level 3
Hello,
I have a problem reading and writing to 25C080. I tried to read and write the 25C080 eeprom with PIC18F452 but not work. So I used the next code on 25C080 but did not work. Can any one help me on what to do? Please
movlw 90h
movwf 0xF94 ; set input TRISC ( RX and SDI)
movlw 80h
movwf 0xFC7 ; SMP=1 from SSPSTAT
movlw 31h
movwf 0xFC6 ; SSPEN=1, ckp=1, FC/16 from SSPCON1
write_10
bcf 0xF83, 1 ; low chip select
movlw 01h ; write status register (WRSR)
call output
movlw 06h ; enable write operation (WREN)
call output
movlw 02h ; write data to memory array... (WRITE)
call output
movlw 00h ; write MSB address
call output
movlw 0Ah ; write LSB address
call output
movlw 33h ; write data
call output
bsf 0x F83, 1 ; high chip select
movlw 04h ; disable write operation (WRDI)
call output
bsf 0xF83,1 ; high chip select
call delay ; 5ms delay
return
read_10
movlw 05h ; read status register (RDSR)
call output
movlw 03h ; read data from memory (READ)
call output
movlw 00h ; read MSB address
call output
movlw 0Ah ; read LSB address
call output
movwf label ; RAM memory
return
output
movwf 0xFC9 ; SSPBUF register
loop
btfss 0xFC7, 0 ; test buffer full status bit
bra lop
retlw 0
Thank you
movlw 90h
movlw 80h
movlw 31h
write_10
call output
call output
call output
call output
call output
call output
call output
return
read_10
call output
call output
call output
call output
return
output
loop
bra lop
retlw 0
Thank you
