+ Post New Thread
Results 1 to 18 of 18
  1. #1
    Newbie level 1
    Points: 1,578, Level: 9
    Join Date
    Mar 2004
    Posts
    Points
    1,578
    Level
    9
    .pcb file
    Files are downloaded from this ie, nd Express PCB cant open them..
    What to sdo
  2. #2
    Advanced Member level 3
    Points: 9,990, Level: 23
    Join Date
    Jun 2003
    Switzerland
    Posts
    901
    Points
    9,990
    Level
    23
    pcb file
    Did you try to open with a text/hex editor to see if there is any text containing some pcb software infos?
  3. #3
    Member level 2
    Points: 1,657, Level: 9
    Join Date
    Mar 2004
    Posts
    45
    Points
    1,657
    Level
    9
    .pcb extension
    I think you can use the tool named
    express pcb
    to open this file because express pcb uses the extension .pcb
  4. #4
    Member level 4
    Points: 2,107, Level: 10
    Join Date
    Dec 2003
    Posts
    73
    Points
    2,107
    Level
    10
    how to open .pcb file
    Tango also uses .pcb
    •   Alt30th March 2004, 09:55
      advertising
  5. #5
    Junior Member level 2
    Points: 2,585, Level: 11
    Join Date
    Oct 2003
    Posts
    22
    Points
    2,585
    Level
    11
    pcb extension
    Also Cadstar, Traxmaker and the old DOS version of Orcad PCB could use *.PCB as I remember. Post the header of the file if it's plain text, could be useful.
  6. #6
    Newbie level 2
    Points: 1,545, Level: 8
    Join Date
    May 2004
    Posts
    Points
    1,545
    Level
    8
    open pcb file
    Greetings,
    Protel for Windows versions before Protel98 all used *.pcb extensions.
    Check out www.altium.com or www.protel.com
    The Protel DXP 2004 demo file is large, however it will open most *.pcb files for you.
    Another solution is to download the Circad demo from www.holophase.com This is a much smaller file to download.
    This will also open Protel/Autotrax *,pcb files.
    If you still have problems you could email it to me and I will see if I can open it for you.
    Regards,
    derekg
  7. #7
    Member level 3
    Points: 1,820, Level: 9
    Join Date
    Jun 2004
    Posts
    66
    Points
    1,820
    Level
    9
    open .pcb file
    hi,
    try with power-pcb, because it has extension .pcb.
  8. #8
    Member level 1
    Points: 2,122, Level: 10
    Join Date
    Apr 2002
    Posts
    38
    Points
    2,122
    Level
    10
    how to open pcb files
    PCAD also uses the *.pcb extension for pcb.
    tyr to open with wordpad like editor.may you get some hint
    rishab
    •   Alt29th June 2004, 14:40
      advertising
  9. #9
    Points: 1,590, Level: 9
    Join Date
    May 2004
    Posts
    Points
    1,590
    Level
    9
    pcb file extension
    Quote Originally Posted by grizli
    What to sdo
    hi
    any pcb program soft ware will open this file as p-cad , orcad, protus,....etc
  10. #10
    Full Member level 3
    Points: 3,228, Level: 13
    Join Date
    May 2001
    China
    Posts
    184
    Points
    3,228
    Level
    13
    pcb file format
    Hi
    You could open with UltraEdit/UltraEdit-32 to see if there is any text containing some pcb software infos.
    ynhe
  11. #11
    Points: 2,359, Level: 11
    Join Date
    Oct 2005
    Posts
    23
    Points
    2,359
    Level
    11
    open pcb files
    There are many programs that uses file extended with pcb like:
    pcad, proteus,
  12. #12
    Full Member level 1
    Points: 4,794, Level: 16
    skywalker's Avatar
    Join Date
    Nov 2001
    Earth
    Posts
    119
    Points
    4,794
    Level
    16
    *.pcb file
    grizli,
    moore cad programs use .pcb extension. Davorin is right.
    Open the .pcb file with worpad or other best ascii editor, then read the initial rows.
    In most cases you can read in initial rows, info on the prog and version, then you need the specific cad.
    skywalker.
  13. #13
    Junior Member level 1
    Points: 1,703, Level: 9
    Join Date
    Nov 2004
    India
    Posts
    17
    Points
    1,703
    Level
    9
    extension pcb
    Try with Cadstar or CR-5000 Board designer both can open files with *.Pcb extension
    rgds,
    prasanna
  14. #14
    Full Member level 3
    Points: 2,770, Level: 12
    Join Date
    Sep 2005
    Lions Den
    Posts
    173
    Points
    2,770
    Level
    12
    how to open .pcb files
    Well, difficult to answer that. There are lots of packages that use .pcb extn. Protel, & pads both use.pcb extn.
    If you try open these it says " unregognized file format".
    If you can read the header file then you might head in right direction.
    •   Alt23rd March 2006, 05:47
      advertising
  15. #15
    Points: 9,214, Level: 22
    cyberrat's Avatar
    Join Date
    Jun 2001
    In the sewers of the U.K.
    Posts
    859
    Points
    9,214
    Level
    22
    Yes, in the header of the file there may well be a hint to the company that owns the rights to the file
    format.
    Perhaps opening it with word/notepad, etc may display somehting.
    Please do not PM me questions that are better asked in the PCB forum :)
  16. #16
    Full Member level 6
    Points: 4,262, Level: 15
    Join Date
    Dec 2005
    BANGALORE
    Posts
    373
    Points
    4,262
    Level
    15
    .pcb file format
    Its simple,open the pcb file in word and look into the header line for software name and version.........hope this will help you.
    Regards
    Rame
  17. #17
    Advanced Member level 2
    Points: 5,187, Level: 17
    Achievements:
    7 years registered
    Join Date
    Dec 2006
    India
    Posts
    507
    Points
    5,187
    Level
    17
    open pbc file
    TRY to look into its property which software it was routed in, Cadstar and PowerPCB uses the same extension.
    ricky
  18. #18
    Newbie level 1
    Points: 386, Level: 4
    Join Date
    Oct 2010
    San Jose, California
    Posts
    Points
    386
    Level
    Re: How to open file that has PCB extension
    As well as helping you open various countless file extensions, FileCure works to make sure that your Windows computer deals with files smoothly. At times file formats can become associated with the wrong programs. For example, Microsoft Paint might be associated with your music files. Every time you try to listen to a new tune or audio joke that someone sent you as an .mp3 file, Paint tries to open and error occurs. With FileCure's Manage feature, it is easy to assign MP3 files to Windows Media Player, VLC Player or whichever music player you prefer. And keep it that way.
