Motor Types servo motor - shaft encoder motor??
FMradio
Member level 3
Heaven
Motor Types ??
i want to know about some motors like
1) servo motor
2) shaft encoder motor
I need some basic Tutorials ??
how to connect shaft encoder with microcontroller ??
Re: Motor Types ??
Encoders
Encoders use rotating disks with optical windows, as shown in Figure. The encoder contains an optical disk with fine windows etched into it. Light from emitters passes through the openings in the disk to detectors. As the encoder shaft is rotated, the light beams are broken.
There are two fundamental types of encoders; absolute and incremental. An absolute encoder will measure the position of the shaft for a single rotation. The same shaft angle will always produce the same reading. The output is normally a binary or grey code number. An incremental (or relative) encoder will output two pulses that can be used to determine displacement. Logic circuits or software is used to determine the direction of rotation, and count pulses to determine the displacement. The velocity can be determined by measuring the time between pulses.
Encoder disks are shown in Figure 14.4. The absolute encoder has two rings, the
outer ring is the most significant digit of the encoder, the inner ring is the least significant digit. The relative encoder has two rings, with one ring rotated a few degrees ahead of the other, but otherwise the same. Both rings detect position to a quarter of the disk. To add accuracy to the absolute encoder more rings must be added to the disk, and more emitters and detectors. To add accuracy to the relative encoder we only need to add more windows to the existing two rings. Typical encoders will have from 2 to thousands of windows per ring.
