+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Advanced Member level 3
    Points: 6,852, Level: 19
    SphinX's Avatar
    Join Date
    Jan 2002
    EGYPT
    Posts
    822
    Points
    6,852
    Level
    19
    pic16f877 development board
    I want to build one.
    Thanx
  2. #2
    Full Member level 5
    Points: 3,856, Level: 14
    Join Date
    May 2002
    from istanbul in TURKEY
    Posts
    290
    Points
    3,856
    Level
    14
    pcb pic16f877a project
    •   Alt27th March 2004, 02:19
      advertising
  3. #3
    Member level 4
    Points: 2,553, Level: 11
    Join Date
    Jan 2003
    Portugal
    Posts
    75
    Points
    2,553
    Level
    11
    pic development board protel
    Take a look at the the PrimeKit PIC Development Board II.
    http://www.primetec.pt/products.php?...prod=6&lang=en
    or
    http://www.primetec.pt/index_en.php
    PrimeKit PIC DevBoard II is a development board for Microchip® PICmicro®
    micro-controllers, and programming of Microchip® PICmicro® microcontrollers
    can be learned, by exploring the 12C/Fxxx, 16C/Fxxx, and 18C/Fxxx families.
    PrimeKit PIC DevBoard II configuration is done by Jumpers, that allow
    activation/deactivation of all peripherals. All peripherals that share the
    same micro-controller BUS, are in parallel. If in need of any outside
    component testing, the provided Proto-board may be used, as well as the
    flat-cable sockets.
    The Radio Transceiver, USB and Ethernet modules are optional, although they
    may be supplied with the PrimeKit PIC DevBoard II.
    You may find this on the webpage, but here it goes
    Peripherials included onboard:
    Momentary switch buttons and 12 keys numeric keyboard;
    16x2 chars LCD Display;
    Leds BUS and 7 segments HEX Displays;
    USART (Serial Port);
    USB (Universal Serial Bus);
    Ethernet port accessed by I²C ®
    BUS I²C ® , SPI® and CAN BUS;
    Radio Transceiver for 433.92MHz;
    Crystal Oscillator or external fixed/variable clock;
    Temperature Sensor accessed by 1-wire® technology;
    Triac for AC/DC power circuit switching;
    EEPROM Memory accessed by I²C ® technology;
    Real Time Clock accessed by I²C ® technology;
    Analogue Inputs to use with PIC's ADC's;
    Total access from outside to the micro-controller ports;
    External pulse input;
    ICD (In Circuit Debugger) - Step-by-step debugging;
    Proto-board for auxiliary circuit testing;
    * Compatible with RS232/USB Bootloader. *
    * Compatible with BasicStamp *
    regards
    asena
    1 members found this post helpful.
  4. #4
    Full Member level 5
    Points: 3,962, Level: 14
    sokrat's Avatar
    Join Date
    Sep 2002
    EGYPT
    Posts
    277
    Points
    3,962
    Level
    14
    pic16f board
    dear mbyka
    if you have PCB for this Development Board please send it
    S 8O KRAT
  5. #5
    Full Member level 5
    Join Date
    May 2002
    Posts
    290
    Points
    3,856
    Level
    14
    pic16f877 development board circuit
    I am sorry I don't have
  6. #6
    Full Member level 5
    Points: 4,121, Level: 15
    Join Date
    Apr 2002
    thailand
    Posts
    318
    Points
    4,121
    Level
    15
    pic 16f877 development kit
    I have
    enjoy to develop :D
  7. #7
    Points: 5,272, Level: 17
    Join Date
    Jun 2002
    India
    Posts
    840
    Points
    5,272
    Level
    17
    pic development board schematic
    Hi nooknikz,
    The rar file seems to have some problems. Is it the cadstar PCB file.
    TIA
    BRM
  8. #8
    Full Member level 5
    Join Date
    Apr 2002
    thailand
    Posts
    318
    Points
    4,121
    Level
    15
    pic16f877 development boards
    unzip cp877v12.rar by winrar v3.0 up
    and open cp877v12.pcb by protel (pcb) v2.5 or protel 99 se
  9. #9
    Full Member level 5
    sokrat's Avatar
    Join Date
    Sep 2002
    EGYPT
    Posts
    277
    Points
    3,962
    Level
    14
    pic16f877a pcb
    Quote Originally Posted by nooknikz
    and open cp877v12.pcb by P*otel (pcb) v2.5 or P*otel 99 se
    DEAR nooknikz very thanks but i dont have protel
    you can convert it to PDF please
    thanks
    S 8O KRAT
    •   Alt30th March 2004, 09:17
      advertising
  10. #10
    Full Member level 4
    Points: 5,939, Level: 18
    Join Date
    Sep 2001
    France
    Posts
    214
    Points
    5,939
    Level
    18
    pic16f877 project board with pcb layout
    hello,
    This is the pdf version of the board.
    I'm not sure it is simple to realize it.
    CD:)
  11. #11
    Full Member level 5
    sokrat's Avatar
    Join Date
    Sep 2002
    EGYPT
    Posts
    277
    Points
    3,962
    Level
    14
    pic16f877a pcb board
    Dear nooknikz
    it is not mbyka Development Board
    please send Schematic as PDF
    THANKS
    S 8O KRAT
  12. #12
    SphinX's Avatar
    Join Date
    Jan 2002
    EGYPT
    Posts
    822
    Points
    6,852
    Level
    19
    pic16f877 pcb
    Hi Sokrat,
    Why do you want the schematic?
    The component values are shown in the placement diagram.
    Bye
  13. #13
    Full Member level 5
    Join Date
    May 2002
    Posts
    290
    Points
    3,856
    Level
    14
    pic16f877 development board schematic
    another schema
    PIC-EASY-shematic.pdf
  14. #14
    Full Member level 5
    sokrat's Avatar
    Join Date
    Sep 2002
    EGYPT
    Posts
    277
    Points
    3,962
    Level
    14
    pic16f877 dev kit free
    Quote Originally Posted by SphinX
    Hi Sokrat,
    Bye
    Don't start any project before you sure all resource with you
    S 8O KRAT
  15. #15
    Full Member level 3
    Points: 3,274, Level: 13
    Join Date
    Jan 2004
    Singapore
    Posts
    154
    Points
    3,274
    Level
    13
    pic16f877a circuit
    Hi, John Peatman got a great book on PIC18F455, this book comes with a free PCB for PIC18F455. You can save great value using this PCB to build a PIC18F455 board, intsead PIC16F877. Both ICs are pin compatible; just that PIC18 has more flash memory. It comes with a RJ Socket for ICD debugger + programming.
    http://www.picbook.com/qwikflash.html
  16. #16
    Full Member level 5
    sokrat's Avatar
    Join Date
    Sep 2002
    EGYPT
    Posts
    277
    Points
    3,962
    Level
    14
    pic16f877a pcb layout
    DEAR lguancho
    do have this book as PDF
    S 8O KRAT
  17. #17
    Full Member level 3
    Join Date
    Jan 2004
    Singapore
    Posts
    154
    Points
    3,274
    Level
    13
    pic16f877a development board schematic
    Nope, I don't have the ebook for it. I bought the hardcopy because I want to use the PCB.
    By the way, to fabricate this PCB (FR4 2 layer board) is also half the cost of the book. If you buy the book, it comes free. Really worth it.
    I tried to scan some books before, believe me, the quality is really bad. You need to do some image processing.
    •   Alt12th April 2004, 06:57
      advertising
  18. #18
    Junior Member level 2
    Points: 1,922, Level: 10
    snaper's Avatar
    Join Date
    Feb 2004
    Posts
    21
    Points
    1,922
    Level
    10
    pic16f877a circuit board
    hi mbyka
    Do u have pic easy in the protel format instead of pdf and also pcb layout for it to
    thanks
    snaper
  19. #19
    Full Member level 5
    Join Date
    May 2002
    Posts
    290
    Points
    3,856
    Level
    14
    pic16f877a development kit schematic
    no I am sorry :(
  20. #20
    Newbie level 1
    Points: 777, Level: 6
    Join Date
    Aug 2008
    Posts
    Points
    777
    Level
    pic16f877 & development board & schematic
    For 8, 16, 32bit micro-controller development board in India visit:
    www.agileworldwide.com
