Simulink - Mapping Sequence and QPSK Modulation
todorare
Newbie level 1
Hello everyone!
Being new to matlab I 've been struggling to simulate QPSK modulation for the IEEE 802.15.4 in Simulink. So, I generate a random integer number from 0-15 which in order to convert to binary i pass through a integer to bit converter block with an output of 4 bits. Then I want to map the output to 32 bit sequences and that's where the problem starts.
I am trying to do that by adding a Lookup Table but I need to map two binary sequences and it seems that the Lookup Table "sees" the data that I am trying to insert as decimal. Is there a way to change that? Or use another block for binary mapping? And in addition to that is there a way to check the integer to bit block's output?
Any help would be valuable!
Thanks
Teo
