step motor controller - motor is unknown
filjoa
Member level 4
hi
I try control an step motor, but I don't have datasheet of motor, because I remove them from printer.
this is my motor reference 17pm-k041-p2f:
on my program I make:
output_high(PIN_B7);
delay_ms(10);
output_low(PIN_B7);
delay_ms(10);
output_high(PIN_B6);
delay_ms(10);
output_low(PIN_B6);
delay_ms(10);
output_high(PIN_B5);
delay_ms(10);
output_low(PIN_B5);
delay_ms(10);
output_high(PIN_B4);
delay_ms(10);
output_low(PIN_B4);
delay_ms(10);
in each pin I have an NPN MOSFET.
my question is how I know where PIN put each thread, I have 5.... how I can dicide this?
best regards.
Re: step motor controller
First, try to identify wires of your stepper motor ..
Here is a procedure that may help you:
Then you can start generating stepping sequences ..
See this:
Rgds,
IanP
    filjoa
