+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Advanced Member level 1
    Points: 4,355, Level: 15
    Join Date
    Nov 2004
    Posts
    451
    Points
    4,355
    Level
    15
    Low Pass filter making problem
    Hi, I'm trying to read temperature with a thermocouple for which i have made a amplifying circuit after which i feed the amplified voltage to a Low-pass filter to remove any noise. To be very frank i don't know how to design a LPF but after seeing from some applications i have used one which i have shown in attached diagram. This LPF is itself introducing huge noise. The output voltage is'nt stable after this like it's jumping anywhere between 674mV to 698mV at a particular fixed input voltage. If I remove this LPF the output is very stable. But I think I may need this LPF because I have to use this circuit in noisy industrial conditions.
    Please tell me what mistake I'm making.
    Thanks
    •   Alt24th November 2009, 14:38
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Re: Low Pass filter making problem
    Hi GARG29,
    1.) Use any universal opamp but not LM324
    2.) Use dual supply (if available) instead of single supply (as mentioned in the doc)
    3.) Single supply works only if the output of the first amplifying stage in the figure has a dc component of app. 1/2 Vdd. I suppose this is not the case for your application.
    4.) The R,C components yield a 3-dB-corner frequency of app. ω=2000 1/rad.
    Does this satisfy your requirements?
    Further questions?
    1 members found this post helpful.
