Is it possible to use Coldvision AVR C source in AVR studio?
nihal_2000
Member level 1
India
Hi guy's
I wanted to some project. I found similar project code in Codevision AVR C. I am using AVR studio, can I use the same c program in AVR studio without any change. Code includes C source fiel, PRJ file and .hex file.
Program is written in C, I think it can be used with some modification, If that is the case then please guide me what modification it needs?
What is the difference between Codevision AVR C and atmel AVR C compiler?
Please guide me…..thanks to all!
The main difference is that Atmel doesn't actually provide a C compiler with AVR Studio...
Sorry, you cannot use codevision program directly in avr studio. (Assuming that you are using winavr)
You have to modify a little bit and it is so simple.
Thanks Nandhu,
Could you please guide me, as what sort of modification it requires.....?
Thanks to all!
Re: Is it possible to use Coldvision AVR C source in AVR stu
Hi Nihal,
Good to see u
I think win avr gcc compiler is suitable for AVR studio.
The difference between Codevision AVR C and atmel AVR C (Win AVR) compiler is the syntax.
You have to change the syntax for compiler to compiler. Each compiler is having there own syntax & header file.
Syntax is to access the internal peripheral & I/O port of the microcontroller.
Regards
Chanchal
