Need optimization fir filter program
blueteeth
fir filter programming
For my fir filter,I need a low taps fir for implementation.I had tried windows and remez method,but the taps is too high.
I heard that optimization fir filter design method is good,anyone can provide some program or papers about it to help finish the design.
fir filter program
Optimization fir filter? I can not understand what it is. I know, we can simply design the fir filter using fdatool.
OK! what is your sampling freq. decrease it.
convex optimization
what is your requirement?
Try IIR,it can reduce the tap.
you can use filterwiz...
you can download a demo...
What I mean is the method like linear programming,convex optimization to design fir.I had found some papers about it,but it really a little complicated for me,so I need some example program(matlab code or c code) and more papers,books.Anyone can help me?
U can Mix coefficients of 2 consecutive stages. and add them ,
By the way ur FIR is Low pass or High Pass , tell me in detail
I can only use one stage fir filter.
lowpass,fs=19.6608MHz,fpass=590kHz,fstop=740kHz
passband ripple < 1db, stopband >50db
