+ Post New Thread
Results 1 to 7 of 7
20th March 2004, 03:51 #1
Why TX frequency is lower than RX one in mobile communication?
For mobile communication, TX frequency is always lower than RX frequency. Does anybody know this? and can give reasonable explaination. Thanks
20th March 2004, 04:34 #2
- Join Date
- Feb 2004
- Location
- NE USA
- Posts
- 372
- Helped
- 73 / 73
- Points
- 4,809
- Level
- 16
Re: TX and RX frequency
That's not always the case. It depends on frequency allocations and protocols. For example, CDMA2000 has both situations, depending on the band class. This is probably determined by the services with adjacent allocations.
21st March 2004, 11:00 #3
TX and RX frequency
To comply with FCC frequency allocation:
If you are interested, check out at http://www.fcc.gov/oet/spectrum/table/
22nd March 2004, 13:45 #4
- Join Date
- May 2003
- Posts
- 26
- Helped
- 0 / 0
- Points
- 1,804
- Level
- 9
TX and RX frequency
for example in INMARSAT,Rx is lower than Tx.
Tx 1626.5 - 1660.5 MHz
Rx 1525.0 - 1559.0 MHz
22nd March 2004, 14:16 #5
For GSM, say EGSM, TX frequency is 880~915MHz and RX frequency is 925~960MHz. Are there some special considerations? Say, channel characteristics or RF issues.
22nd March 2004, 17:22 #6
- Join Date
- Jan 2003
- Location
- Greece
- Posts
- 159
- Helped
- 40 / 40
- Points
- 4,641
- Level
- 16
There's no special design consideration that leads to commonly used frequency bands.
Don't forget that in Frequency Division Duplex (FDD) systems (like GSM) the Base-Station TX is Mobile-Station RX and vice-versa...
mogwai.
22nd March 2004, 17:32 #7
- Join Date
- Jul 2002
- Location
- Middle Earth
- Posts
- 4,629
- Helped
- 491 / 491
- Points
- 36,491
- Level
- 46
One thing that drives the frequencies is economics. There are more mobiles than bases. Therefore the system cost is lowest when the mobiles are lower cost. Generally, lower frequencies require hardware with lower costs. Also lower frequencies have more efficient power amplifiers which makes battery life longer.
1 members found this post helpful.
+ Post New Thread
Please login
